WMS client/Terraserver example...
Jerl Simpson
jerl.simpso at GMAIL.COM
Thu Aug 18 20:39:23 EDT 2005
Is the extent restricted to only your county?
It might not make a difference, but try extending your extent to say,
the US. Roughly -125 24 -66 50
Jerl
On 8/18/05, John Cole <john.cole at uai.com> wrote:
> After getting the NEXRAD data projected and working
> (http://mesonet.agron.iastate.edu/docs/radmapserver/howto.html) I wanted to
> get back to terraserver data.
> I created a very simple map file and put all of the layer statements that I
> could find from the mailing list for using terraserver wms. My problem is
> that all I get is a map with my county on it, but I think my problem is that
> I'm behind a proxy server. Is there a way to configure the wms client to
> use a proxy server?
> I would appreciate someone looking at my map file and seeing if it does
> indeed work or let me know what isn't correct.
> Attached is a zip file renamed to zix of my small terraserver test project
> If that doesn't make it through, here is my map file and the html template.
> Thanks,
> John Cole
> #-------------------------- main.map --------------------
> MAP
> # Start of Mapfile (radmapserver.map)
> NAME radmapserver
> STATUS ON
> SIZE 800 600
> #SIZE 150 96
> EXTENT -86.790056 34.475633 -86.255771 34.992296
> UNITS dd
> IMAGETYPE PNG
> # the shape path is the .map file directory
> SHAPEPATH "."
> # fonts.txt for windows XP (strip # sign)
> # ----- cut below this line --------
> # arial C:\WINDOWS\Fonts\arial.ttf
> # ----- cut above this line --------
> FONTSET "fonts.txt"
> # Map projection definition
> PROJECTION
> "init=epsg:4326"
> END
> WEB
> TEMPLATE 'main.html' # template file
> IMAGEPATH "/tmp/ms_tmp/" # web server needs read/write to
> this directory
> IMAGEURL "/ms_tmp/" # web path to the above
> directory (set this in IIS or Apache)
> LOG "test_terra.log"
> END
> LEGEND
> STATUS ON
> IMAGECOLOR 255 255 255
> POSITION UL
> KEYSIZE 20 10
> KEYSPACING 5 2
> LABEL
> TYPE truetype
> FONT arial
> size 8
> OFFSET 0 0
> PARTIALS TRUE
> ANTIALIAS TRUE
> MINDISTANCE -1
> MINFEATURESIZE -1
> COLOR 0 0 0
> END
> END
> # Start of scalebar
> SCALEBAR
> LABEL
> COLOR 0 0 0
> SIZE TINY
> END
> STYLE 0
> SIZE 200 4
> COLOR 0 0 0
> BACKGROUNDCOLOR 255 255 255
> UNITS MILES
> INTERVALS 5
> STATUS on
> END
> # to make a reference image, set the size to 150 96 and
> # uncomment the fill color line in the county style (and comment the outline
> color)
> # save the image as reference.png in the directory your mapfile is in
> # if you do not have a reference.png set the status to OFF
> REFERENCE
> STATUS ON
> SIZE 150 96
> MINBOXSIZE 5
> MAXBOXSIZE 140
> COLOR -1 0 0
> OUTLINECOLOR 255 0 0
> END
> OUTPUTFORMAT
> NAME "png"
> MIMETYPE "image/png"
> DRIVER "GD/PNG"
> EXTENSION "png"
> IMAGEMODE PC256
> TRANSPARENT FALSE
> FORMATOPTION "INTERLACE=ON"
> END
> LAYER
> NAME "photo"
> STATUS ON
> TYPE RASTER
> MINSCALE 10000
> CONNECTIONTYPE WMS
> CONNECTION "http://terraservice.net/OgcMap.ashx?"
> METADATA
> "wms_srs" "EPSG:26910"
> "wms_title" "Orthophoto"
> "wms_name" "DOQ"
> "wms_server_version" "1.1.1"
> "wms_format" "image/png"
> "wms_layers" "doq"
> "wms_group_title" "background"
> END
> PROJECTION
> "init=epsg:26910"
> END
> END
> LAYER
> NAME "aerial"
> TYPE RASTER
> STATUS ON
> CONNECTIONTYPE WMS
> CONNECTION
> "http://terraservice.net/ogcmap.ashx?VERSION=1.1.1&SERVICE=wms&LAYERS=urbana
> rea&FORMAT=image/jpeg&STYLES="
> METADATA
> "wms_srs" "EPSG:4326"
> END
> PROJECTION
> "init=epsg:4326"
> END
> END
> LAYER
> NAME ortho
> METADATA
> "wms_title" "USGS Digital Ortho-Quadrangles"
> LYRNAME "DOQs (orthophotos)"
> LINK
> "http://terraserver.microsoft.com/about.aspx?n=AboutTerraServiceOverview"
> END
> GROUP "BASE DATA"
> STATUS ON
> DEBUG ON
> TYPE RASTER
> MINSCALE 1500
> MAXSCALE 80000
> CONNECTIONTYPE WMS
> CONNECTION
> "http://terraservice.net/ogcmap.ashx?VERSION=1.1.1&SERVICE=wms&LAYERS=DOQ&FO
> RMAT=png&styles="
> PROJECTION
> "init=epsg:4326"
> END
> END
> LAYER
> NAME DOQ17N
> METADATA
> #"wms_srs" "EPSG:26916" #NAD83 UTM zone 16N
> LINK
> END
> STATUS default
> TYPE RASTER
> CONNECTIONTYPE WMS
> CONNECTION
> RMAT=png&styles="
> PROJECTION
> #"init=epsg:26916" #NAD83 UTM zone 16N
> "init=epsg:4326"
> END
> END
> # Madison County, Alabama TIGER County 2000 polygon
> # http://arcdata.esri.com/data/tiger2000/tiger_download.cfm
> LAYER
> NAME "Madison County"
> DATA "tgr01089cty00"
> METADATA
> "wms_title" "Madison County"
> END
> PROJECTION
> "init=epsg:4326"
> END
> STATUS default
> TYPE POLYGON
> CLASS
> STYLE
> OUTLINECOLOR 0 255 0
> #COLOR 242 236 223
> END
> END
> END
> END
> <!-- --------------------------- main.html --------------------------------
> <html xmlns="http://www.w3.org/1999/xhtml">
> <head>
> <meta name="generator" content=
> "HTML Tidy for Windows (vers 1st June 2004), see www.w3.org" />
> <title>MapServer Workshop</title>
> <meta http-equiv="Content-Type" content=
> "text/html; charset=us-ascii" />
> <link type="text/css" rel="stylesheet" href=
> "/projects/tutorial/ms35.css" />
> </head>
> <body bgcolor="#FFFFFF" text="#000000">
> <h3>Terraserver Sample Map View</h3>
> <!-- START OF MAPSERVER FORM -->
> <!-- you will need to set the action to point to where your mapserver
> executable is -->
> <form name="mapserv" method="get" action="/cgi-bin2/mapserv.exe"
> id="mapserv">
> <!-- HIDDEN MAPSERVER CGI VARIABLES -->
> <input type="hidden" name="map" value="[map]" />
> <input type="hidden" name="imgext" value="[mapext]" />
> <input type="hidden" name="imgxy" value="199.5 149.5" />
> <input type="hidden" name="layers" value="[layers]" />
> <table width="400" border="1">
> <tr>
> <td>
> <!-- SPECIFY MAP MODE -->
> <div align="center">
> Map Mode:<br />
> <select name="mode">
> <option value="browse">
> Browse
> </option>
> <option value="map">
> Map
> </option>
> </select>
> </div>
> </td>
> <td>
> <!-- FORM SUBMIT BUTTON -->
> <input type="submit" name="submit" value="Refresh" />
> </div>
> </td>
> <td>
> <!-- ZOOM/PAN CONTROLS -->
> Map Control:<br />
> <select name="zoom">
> <option value="4" [zoom_4_select]>
> Zoom In 4x
> </option>
> <option value="3" [zoom_3_select]>
> Zoom In 3x
> </option>
> <option value="2" [zoom_2_select]>
> Zoom In 2x
> </option>
> <option value="1" [zoom_1_select]>
> Recenter
> </option>
> <option value="-2" [zoom_-2_select]>
> Zoom Out 2x
> </option>
> <option value="-3" [zoom_-3_select]>
> Zoom Out 3x
> </option>
> <option value="-4" [zoom_-4_select]>
> Zoom Out 4x
> </option>
> </select>
> </div>
> </td>
> <td rowspan="2" valign="top">
> <p>Reference:<br />
> <img name="ref" src="[ref]" id="ref" /></p>
> <p>Legend:<br />
> <img name="legend" src="[legend]" id="legend" /></p>
> </td>
> </tr>
> <tr>
> <!-- DISPLAY THE MAPSERVER-CREATED MAP IMAGE -->
> <td colspan="3" align="center" valign="top">
> <input type="image" name="img" src="[img]" width="800"
> height="600" border="0" />
> <table border="0" width="600" align="center">
> <!-- DISPLAY THE SCALE BAR -->
> <tr>
> <td align="right"><img src="[scalebar]" /></td>
> </tr>
> </table>
> </td>
> </tr>
> </table>
> </form>
> <p>Map scale 1:[scale]</p>
> <p>Pixel size [cellsize]</p>
> <p>Extents [minx], [miny], [maxx], [maxy]</p>
> <p>Map size (screen) [mapsize]</p>
> <p>Map width [mapwidth]</p>
> <p>Map height [mapheight]</p>
> <p>Map [map]</p>
> <p>Layers [layers]</p>
> </body>
> </html>
> This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
