SDE querybypoint no results
Frederico Lucca
fredlucca at GMAIL.COM
Fri Aug 19 12:19:07 EDT 2005
Juan Antonio,
I don't know SDE, but I think the query is the same in every format.
How are you trying this?
Can you post the code?
Best regards,
Fred
On 8/18/05, Juan Antonio Fernandez Prada <juanantonio.fernandez at uca.es> wrote:
> Hello everbody!
> I'm trying to make querys to a shape in SDE. I've got some shapes in
> ArcSDE; the mapserver works fine with them, but when I make querybypoint,
> there in not any results. I think that should be have any form to make
> this, but I don´t know than.
> Does anybody know how to make this? Or, does anybody if I can or can't do
> this?
> An other question: Can I work with MapServer and ArcGis FeatureClass?
> Thanks a lot and regards,
> Juan Antonio.
"Everything under the sun is in tune
But the sun is eclipsed by the moon"
