ASP.NET and mapscript - unable to load DLL
Mike Boos
mboos at AUGSIGNALS.COM
Fri Aug 19 13:23:38 EDT 2005
mapscript_csharp.dll is present in the bin directory. All the others are
in system32. gdal12.dll is in both as I'm somehow invoking a function
from it from elsewhere and not having the slightest bit of trouble with
that part (I'm using a direct DllImport attribute). So maybe I will have
to try one of the alternatives. Oh well.
Mike
Abe Gillespie wrote:
>Did you move mapscript.dll to system32 as well? The only DLL that
>should be in your bin dir is mapscript_csharp.dll.
>Suggestions:
>1. Write the mapfile by hand with the file streaming objects?
>2. Wrap the MapServer CGI executable with ASP.NET (I think someone
>did just this some time ago).
>3. If this is all you're doing, you *might* be able to get away with
>it in ASP.NET. See if there's a way to protect a section of ASP.NET
>code with a semaphore or similar construct. Is there something that
>protects in the virtual thread environment?
>-Abe
>On 8/19/05, Mike Boos <mboos at augsignals.com> wrote:
>>I tried moving the dlls to the system32 directory, but that doesn't have
>>any effect (am I missing any other dependencies?)
>>Unfortunately, I'm kind of stuck with ASP.NET, as that's what the rest
>>of the site relies upon. I'm trying to improve the present setup which
>>involves sending a request to a C++ CGI program which writes a map file
>>to the hard disk and forwards the request to mapserv.exe. If you'd ask
>>me, that's a bit of a kluge, and without Mapscript, all I could do to
>>improve on that would be to take out the C++ program and have the map
>>file generated from within the ASP.NET program itself. Can you think of
>>a better way to accomplish the same task?
>>Mike
>>>Placing the depended-on DLLs into the bin dir will do nothing. I
>>>assume you're on a windows box. Therefore the easiest way to take
>>>care of this is by placing all the DLLs (except for map_script) into
>>><windows>\system32 where <windows> is the system windows directory
>>>(c:\winnt, c:\windows, etc.).
>>>With that said, you're entering a world of pain by using C# map_script
>>>in ASP.NET. Much of the map_script DLL is thread unsafe, that
>>>combined with ASP.NET's supremely weird threading model (e.g. virtual
>>>threads), you're going to encounter a plethora of problems. This is
>>>why you almost never see MapServer + ASP.NET discussion threads.
>>>To get more info, search the archives. You should find ten or so
>>>messages about this topic.
>>>-Abe
>>>On 8/18/05, Mike Boos <mboos at augsignals.com> wrote:
>>>>Hello
>>>>I'm trying to run Mapscript using the SWIG C# bindings on an ASP.NET
>>>>server. I compiled the 4.6.0 version of MapServer and have placed what I
>>>>believe to be the appropriate dependencies (mapscript_csharp.dll,
>>>>mapscript.dll, libmap.dll, bgd.dll, gdal12.dll, pdflib.dll) in the bin
>>>>directory on my server. It is appears to be finding
>>>>mapscript_csharp.dll, but is having trouble finding mapscript.dll or one
>>>>of its dependencies. I am seeing the following error message:
>>>> Server Error in '/' Application.
>>>> /Unable to load DLL (mapscript)./
>>>>* Description: *An unhandled exception occurred during the execution of
>>>>the current web request. Please review the stack trace for more
>>>>information about the error and where it originated in the code.
>>>>* Exception Details: *System.DllNotFoundException: Unable to load DLL
>>>>(mapscript).
>>>>Am I missing a dependency? Or do I need to set some configuration option
>>>>or place the files elsewhere?
>>>>Thanks!
>>>>Mike Boos
