Generating a table & map sharing identifiers
Bill Binko
bill at BINKO.NET
Sun Aug 21 23:20:27 EDT 2005
Hi everyone,
I have a problem that I'd like some feedback on. I'm certain it can be
done, but would like to know how others have solved it in the past.
I need to generate several tables with "nearest X items" to a location.
For example, "Nearest 5 Schools" to a location. I then want to generate a
map showing the area that includes the X items and show the items on the
map using the id's from the table.
Here's an example:
Table:
Map ID |School Name |Students | Teachers
(A) |Main St. Elem. |100 | 10
(B) |Pinewood Elem. |2500 | 20
(C) |Forrest Lakes |800 | 20
Map:
| (A) |
| (B) |
| (C) |
So, what approaches are people using for this when using PostGIS and
Mapserver? I will probably use PHP/Mapscript as that's what I'm most
familiar with.
I have two approaches that I think are doable...
1) I use PHP/Mapscript to make the base map
2) I connect to PostGIS and grab the data including the points/shapes I'm
interested in (OGC WKT format?)
3) I use PHP/Mapscript to create a layer and add the points to the base
map
OR
1) I connect to PostGIS and create a temporary sequence (one that is local
to the connection)
2) I select the data with shapes and attributes + the sequence into a
temporary table (one that is local to the connection)
3) I have PHP/Mapscript draw the map using that temporary table
4) I use the temporary table to generate the HTML
I'm pretty sure everyone will tell me to use approach #1, but of course
I've started #2 :) I think I'm having problems because PHP/Mapscript
opens its own connection to Postgresql, so it won't see my temporary
table.
Does anyone have any advice?
Bill
