point within polygon
Steve Lime steve.lime at DNR.STATE.MN.US
Mon Aug 22 15:41:16 EDT 2005
MapServer has that capability within MapScript. shapeObj's have a contains method
that will tell you if a point is contained in a polygon. E.g.:
  $status = $polygon->contains($point);
The behaviour of the MapServer point-in-polygon algorithm is indeterminent if the point
lies exactly on the edge of the polygon. The return value is consistent though. I guess the
point is that contains really means contains.
Steve
>>> Dylan Beaudette <dylan at IICI.NO-IP.ORG> 08/22/05 1:59 PM >>>
Greetings,
I am currently looking for a way to test if a point is within a polygon,
without using PostGIS. The first method I have tried, and which works but not
well, is with a simple comparison within MySQL:
point at x,y
polygon extent: min_x,min_y,max_x,max_y
if x >= min_x and x <= max_x and y >= min_y and y <= max_y then OK
however, most of my polygons are not rectangular, and thus many point may
seemingly be in multiple polygons when rectangular extents overlap...
is there a better way to do this within mapserver, or phpmapscript?
or is there a postGIS-like patch for MySQL ?
thanks in advance!
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
