OGR Problem
Dave Mitchell dave.mitchell at NEWGROVE.COM
Tue Aug 23 11:30:08 EDT 2005
At a good suggestion from Mapserver-User Bart, I have tried running my ovf
file from a command prompt with ogrinfo, which seems to work fine.
This is what my command prompt says:
Had to open data source read-only.
INFO: Open of `postoffice.ovf'
using driver `VRT' successful.
1: mylayer (Point)
However, I understand that the ODBC drivers may need environment variables
to be set to function correctly through mapserver, can anyone tell me what
I need to do for this.
Also is there a way I can tell whether my PHPMapscript/Chameleon setup is
actually calling the right ogr dlls in Winnt/systrem 32?
Best regards,
Dave
