Postgis/Mapserver-Problem: Tablenames with dots...
Roman Meier
mapserver at GISMAP.CH
Tue Aug 23 13:36:45 EDT 2005
Dear List
Im having a problem with Postgis/Postgresql and Mapserver. I searched the
archives but found no solution.
The error-message in Mapserver shows the following:
msDrawMap(): Image handling error. Failed to draw layer named
'test22_gr.planrahmen.koordinatenlinie'.
prep_DB(): Query error. Error executing POSTGIS DECLARE (the actual query)
statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d(wkb_geometry)),'NDR'),OID::text from
test22_gr.planrahmen.koordinatenlinie WHERE wkb_geometry &&
setSRID('BOX3D(699649.975666667 261476.466,700649.975666667
262476.466)'::BOX3D,
find_srid('','test22_gr.planrahmen.koordinatenlinie','wkb_geometry') )'
Postgresql reports the error as 'ERROR: cross-database references are not
implemented: "test22_gr.planrahmen.koordinatenlinie" '
More Help:
Error with POSTGIS data variable. You specified '<check your .map file>'.
Standard ways of specifiying are :
(1) 'geometry_column from geometry_table'
(2) 'geometry_column from (<sub query>) as foo using unique <column name> using
SRID=<srid#>'
Make sure you put in the 'using unique <column name>' and 'using SRID=#' clauses
in.
For more help, please see http://postgis.refractions.net/documentation.php
Mappostgis.c - version of Jan 23/2004.
The mapfile contains:
LAYER
NAME 'test22_gr.planrahmen.koordinatenlinie'
GROUP Linie
TYPE LINE
STATUS ON
CONNECTIONTYPE postgis
CONNECTION 'user=test dbname=test host=127.0.0.1'
DATA "wkb_geometry from test22_gr.planrahmen.koordinatenlinie"
CLASS
TEMPLATE 'template/test22_gr.planrahmen.koordinatenlinie.html'
SYMBOL 'circle'
SIZE 1
COLOR 256 236 169
END
TOLERANCE 5
END
Analysis:
I get the same error-message if I query the table
'test22_gr.planrahmen.koordinatenlinie' using PSQL:
Select * from test22_gr.planrahmen.koordinatenlinie
--> 520=# ERROR: cross-database references are not implemented:
If I query the table by adding quotation marks everything works fine:
Select * from "test22_gr.planrahmen.koordinatenlinie"
Remark: the dots are part of the tablename!
I tried to do analog changes to the mapfile by changing the following line:
Into DATA "wkb_geometry from 'test22_gr.planrahmen.koordinatenlinie'"
Well - this doesnt work and I cant solve the problem.
Any ideas...?
Thanks in advance
Roman
