Postgis/Mapserver-Problem: Tablenames with dots...
Bill Binko bill at BINKO.NET
Tue Aug 23 14:11:47 EDT 2005
On Tue, 23 Aug 2005, Roman Meier wrote:
> Analysis:
> I get the same error-message if I query the table
> 'test22_gr.planrahmen.koordinatenlinie' using PSQL:
> Select * from test22_gr.planrahmen.koordinatenlinie
> --> 520=# ERROR:  cross-database references are not implemented:
> „test22_gr.planrahmen.koordinatenlinie“
> If I query the table by adding quotation marks everything works fine:
> Select * from "test22_gr.planrahmen.koordinatenlinie"
> Remark: the dots are part of the tablename!
> I tried to do analog changes to the mapfile by changing the following line:
> DATA "wkb_geometry from test22_gr.planrahmen.koordinatenlinie"
> Into DATA "wkb_geometry from 'test22_gr.planrahmen.koordinatenlinie'"
> Well - this doesn’t work and I can’t solve the problem.
> Any ideas...?
Roman,
	First: quoting is a problem in mapfiles.  There is a bug on it,
and it is inconsistent.  However, you probably cannot wait for a solution.
How about this (from PSQL):
CREATE VIEW mapserv_view AS SELECT oid, * from
"test22_gr.planrahmen.koordinatenlinie";
Then you'll need to use the other form of the DATA statement since you
won't have the SRID in geometry_columns table anymore:
DATA "wkb_geometry from (select wkb_geometry from mapserv_view) as innerQ
using SRID=12345"
Where 12345 is is the SRID of your geometry.
That should get you around this.
Hope this helps
Bill
