msautotest/regression testing question
Frank Warmerdam fwarmerdam at GMAIL.COM
Wed Aug 24 09:13:20 EDT 2005
On 8/24/05, Gambin Dejan <Dejan.Gambin at pula.hr> wrote:
> Hi,
> I suppose this question is mostly intended to Frank but maybe someone
> else can answer too.
> I would like how this thing is working and can it be used (at least
> partially) to help me implement some kind of benchmarking that would
> simulate a number of simultaneous visitors doing the map actions
> (zooming, panning, activating/deactivating layers, querying, etc.).
> This would help me decide on hardware requirements and especially the
> Internet bandwidth that I need to lease form my ISP.
Dejan,
I don't think the msautotest provides a very good example
of how to simulate use loading.   It mostly uses shp2img,
avoiding some of the issues related to mapserv running
as a cgi, bandwidth issues, etc.
If you have your application working already, and you
just want to  test it under load, I would suggest operating
it interactively, and capturing the set of requests from
the Apache logfile.  You can then play back the request
series, perhaps with several parallel streams of requests
to simulate load.
I'm not sure what the best way is to determine bandwidth
requirements.  A rough estimate could be collected from the
byte counts reported in the apache log file for a given
series of requests.
Best regards,
