php_mapscript - showing polygon and point/annotation layers
Mike Reilly
mikereilly2 at GMAIL.COM
Wed Aug 24 18:53:13 EDT 2005
Robert and list:
I think I've got this worked out. My original cgi-mapserver application used
a hack to get both point and polygon data able to be filtered based on some
extra data in their respective dbf files - namely site usage (USE1). As a
result I had 3 layers with the same name as each other. While the cgi
handled this fine, it appears that php is less forgiving. I started a .map
file over again for my php application and have renamed the layers and
everything seems to be much happier now.
Next major task on my list - create an interface to allow the creation of
polygons to add to polygon shapefiles - whee!
Thanks again for your help.
Regards,
Mike
On 8/24/05, robert fritz <robert-fritz at web.de> wrote:
> Hi Mike,
> If you want to draw some specific layers you can try this ::
> 1) Switch off all Layers
> function setAllLayerOff($MapObject)
> $layers = $MapObject->getAllLayerNames();
> for($a=0;$a<count($layers);$a++)
> $tmp = $MapObject->getlayerbyname($layers[$a]);
> $tmp->set("status",0);
> 2) Switch on the layers you want to see in your map
> $layer_on = $MapObject->getlayerbyname($layername);
> $layer_on->set("status",1);
> 3) Draw the map and save it
> $objImage=$objMap->draw();
> $image_url=$objImage->saveWebImage();
> Mit der Gruppen-SMS von WEB.DE <http://WEB.DE> FreeMail können Sie eine
> SMS an alle
> Freunde gleichzeitig schicken: *http://freemail.web.de/features/?mc=021179
> * <http://freemail.web.de/features/?mc=021179>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050824/c49fb396/attachment.html
