Solaris 10: libgdal.so.1
Christian Schaffer
christian.schaffer at MUENCHEN.DE
Thu Aug 25 04:19:54 EDT 2005
Hi Josh,
thanks a lot for the advice.
I recompiled mapserver with LD_OPTIONS set in my environment. Calling it
via browser now works perfectly.
Thanks once again,
Chris
Joshua Buysse schrieb:
> Christian Schaffer wrote:
>> Hi all,
>> I´m working on establishing a mapserver environment for our intranet.
>> Since I´m pretty new to UMN mapserver, I´d like to apologize in
>> advance for any stupid questions I might ask.
>> Here´s my problem:
>> I´m on an AMD Opteron based server, Solaris 10 installed with perl
>> 5.8.7, freetype 2.1.10, gd 2.0.33, proj4 4.4.8, curl 7.14.0 and a
>> couple more packages (gcc, bison, binutils, apache, apache2, several
>> libs...) installed from blastwave.org.
> [munch]
>> Seems to be alright up to here, but as soon as I try to call the
>> mapserv binary via http, it won´t work.
>> The message in my apache´s error_log reads:
>> [Tue Aug 23 13:29:10 2005] [error] [client 10.3.3.233] ld.so.1:
>> /data/www/faithless/cgi-bin/mapserv: fatal: libgdal.so.1: open
>> failed: No such file or directory
>> [Tue Aug 23 13:29:10 2005] [error] [client 10.3.3.233] Premature end
>> of script headers: mapserv
>> The libgdal.so.1 can be found in /usr/local/lib:
>> # ll /usr/local/lib/libgdal.so.1
>> lrwxrwxrwx 1 root root 16 Aug 23 11:32
>> /usr/local/lib/libgdal.so.1 -> libgdal.so.1.8.0
>> My apache gets the following LD_LIBRARY_PATH as environment variable:
>> /opt/csw/apache2/lib:/opt/csw/lib:/opt/csw/gcc3/lib:/opt/csw/include:/opt/csw/kde-gcc/lib:
>> /opt/csw/kde-gcc/include:/usr/local/lib:/usr/local/qt/lib:/opt/sfw/lib:/usr/sfw/lib:
>> /usr/local/pgsql/lib:/opt/oracle/lib
>> I tried with apache 1.3.x as well as with apache 2.0.x, changed the
>> LD_LIBRARY_PATH to any variation, I could imagine. But no success yet.
>> As far as I know, there´s no construction similar to Linux´s
>> /etc/ld.so.conf and ldconfig on Solaris. So LD_LIBRARY_PATH seems the
>> only way for me to change the behaviour.
> Actually, there is an equivalent to ld.so.conf -- but it's not
> something that you really want to use if you can avoid it. It's not
> really supported or well documented, as far as I can tell. The best
> way to handle this is to either set LD_OPTIONS or LD_RUN_PATH.
> An example setting that I use (as a blastwave.org maintainer) is this:
> LD_OPTIONS='-R/opt/csw/lib -L/opt/csw/lib -R/usr/local/lib
> -L/usr/local/lib'
> export LD_OPTIONS
> This example assumes that you're using the Sun compilers -- I have not
> tested it with GCC, but I think it should work. If it fails to
> compile, you may need to change it (depending on the way that it's
> linking) to look more like this:
> LD_OPTIONS='-Wl,--rpath -Wl,/opt/csw/lib -L/opt/csw/lib'
> To check the generated binary and see if it can find the libraries,
> you can run 'ldd -s mapserv' and look over the output. It will show
> the library search path embedded in the binary and will tell you which
> libraries it's linking against -- handy for things like libz.so that
> exist in both /usr/lib and /opt/csw/lib (hint: you probably want the
> /opt/csw version).
> Email me if you're trying to use optimized sparcv8plusb or sparcv9
> binaries or libraries. It gets more complicated then.
> One last thing -- if you're trying to link any C++ code against
> libraries (that are written in C++, like geos) in /opt/csw, you will
> need to use the Sun compilers. No way around it.
>> I´d appreciate any suggestion!
>> Thank you very much for helping and best regards,
>> Chris
> -Josh
> (aka buysse at blastwave.org)
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050825/76e03054/attachment.html
