wfs server problem
Mehdi Kiman
oubinny at HOTMAIL.COM
Thu Aug 25 11:14:22 EDT 2005
Sorry i do that but i have always the same problem
>From: "Bart van den Eijnden" <BEN at Syncera-ITSolutions.NL>
>To: <oubinny at hotmail.com>
>CC: <MAPSERVER-USERS at LISTS.UMN.EDU>
>Subject: Re: [UMN_MAPSERVER-USERS] wfs server problem
>Date: Thu, 25 Aug 2005 17:07:05 +0200
>You should add DUMP TRUE to your LAYER.
>Best regards,
>Bart
>Syncera IT Solutions
>Postbus 270
>2600 AG DELFT
>tel.nr.: 015-7512436
>email: BEN at Syncera-ITSolutions.nl
> >>> "Mehdi Kiman" <oubinny at hotmail.com> 08/25/05 5:04 pm >>>
>Now getCapabilities is ok. But when i make a
>http://emir:8080/cgi-bin/mywfs.exe?&SERVICE=WFS&REQUEST=getfeature&VERSION=1.0.0&TYPENAME=Parcelles
>The WFS server output is
><ServiceException>msWFSGetFeature(): WFS server error. TYPENAME 'Parcelles'
>doesn't exist in this server. Please check the capabilities and reformulate
>your request.</ServiceException>
>I'm so surprised beacause my getCapabilities return is correct.
> >To: <oubinny at HOTMAIL.COM>
> >Date: Thu, 25 Aug 2005 16:53:08 +0200
> >Yes, the same MAP file can serve both WMS and WFS.
> >Bart
> >Postbus 270
> >2600 AG DELFT
> > >>> Mehdi Kiman <oubinny at HOTMAIL.COM> 08/25/05 4:51 pm >>>
> >I can have the same MapFile for using both WFS and WFS serveur ?
> > >To: <oubinny at HOTMAIL.COM>,<MAPSERVER-USERS at LISTS.UMN.EDU>
> > >Date: Thu, 25 Aug 2005 16:34:53 +0200
> > >When you are doing a GetCapabilities, what is your URL?
> > >Do you add &service=WFS&request=GetCapabilities&version=1.0.0
> > >otherwise probably the default is the WMS capabilities and you miss
> > >"wms_title" METADATA for that. If you want to be shorter, use the more
> > >general ows_title and leave out wfs_title and wms_title.
> > >Best regards,
> > >Bart
> > >Postbus 270
> > >2600 AG DELFT
> > > >>> Mehdi Kiman <oubinny at HOTMAIL.COM> 08/25/05 4:29 pm >>>
> > >Hi,
> > >I have a problem with my WFS server, i tried to configure it.
> > >My MapFile is correct :
> > >MAP
> > >NAME "Pays_nee_de_la_mer"
> > >DEBUG on
> > >SIZE 600 400
> > >STATUS ON
> > >EXTENT 310559.98 2147175.0 335547.03 2176659.97
> > >FONTSET "../data/fonts.txt"
> > >UNITS METERS
> > >SHAPEPATH "../data/data_map/"
> > >WEB
> > > IMAGEPATH 'C:/tmp/ms_tmp/'
> > > IMAGEURL '/ms_tmp/'
> > > METADATA
> > > "wfs_title" "wfs Pays Ne de La Mer"
> > > "wfs_onlineresource"
> > >"http://emir:8080/cgi-bin/mywfs.exe?config_wfs.map&"
> > > "wfs_srs" "epsg:27582"
> > > "wfs_feature_info_mime_type" "text/html"
> > > END
> > >END
> > >LAYER
> > > CONNECTIONTYPE OGR
> > > CONNECTION "../data/data_map/Parcelles.TAB"
> > > NAME "Parcelles"
> > > TYPE POLYGON
> > > STATUS ON
> > > #STYLEITEM "AUTO"
> > > CLASS
> > > NAME "Parcelles"
> > > TEMPLATE "ttt.html"
> > > STYLE
> > > COLOR 255 255 0
> > > OUTLINECOLOR 0 0 2
> > > END
> > > END
> > > METADATA
> > > "wfs_title" "Parcelles"
> > > END
> > > PROJECTION
> > > "init=epsg:27582"
> > > END
> > >END
> > >And when i make a GetCapabilities, i have this kind of error for each
> >layer
> > ><!-- WARNING: Mandatory metadata '..._title' was missing in this
>context.
> > >What's wrong with my server ?
> > >Thanks
> > >Mehdi
