wfs server problem
Bart van den Eijnden BEN at SYNCERA-ITSOLUTIONS.NL
Thu Aug 25 11:17:25 EDT 2005
Is this typename in your WFS GetCapabilities response (can you post it to the list)?
Try also adding TEMPLATE "blank.html" to your LAYER.
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG  DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Mehdi Kiman <oubinny at HOTMAIL.COM> 08/25/05 5:14 pm >>>
Sorry i do that but i have always the same problem
>From: "Bart van den Eijnden" <BEN at Syncera-ITSolutions.NL>
>To: <oubinny at hotmail.com>
>CC: <MAPSERVER-USERS at LISTS.UMN.EDU>
>Subject: Re: [UMN_MAPSERVER-USERS] wfs server problem
>Date: Thu, 25 Aug 2005 17:07:05 +0200
>You should add DUMP TRUE to your LAYER.
>Best regards,
>Bart
>Postbus 270
>2600 AG  DELFT
> >>> "Mehdi Kiman" <oubinny at hotmail.com> 08/25/05 5:04 pm >>>
>Now getCapabilities is ok. But when i make a
>http://emir:8080/cgi-bin/mywfs.exe?&SERVICE=WFS&REQUEST=getfeature&VERSION=1.0.0&TYPENAME=Parcelles
>The WFS server output is
><ServiceException>msWFSGetFeature(): WFS server error. TYPENAME 'Parcelles'
>doesn't exist in this server. Please check the capabilities and reformulate
>your request.</ServiceException>
>I'm so surprised beacause my getCapabilities return is correct.
> >To: <oubinny at HOTMAIL.COM>
> >Date: Thu, 25 Aug 2005 16:53:08 +0200
> >Yes, the same MAP file can serve both WMS and WFS.
> >Bart
> >Postbus 270
> >2600 AG  DELFT
> > >>> Mehdi Kiman <oubinny at HOTMAIL.COM> 08/25/05 4:51 pm >>>
> >I can have the same MapFile for using both WFS and WFS serveur ?
> > >To: <oubinny at HOTMAIL.COM>,<MAPSERVER-USERS at LISTS.UMN.EDU>
> > >Date: Thu, 25 Aug 2005 16:34:53 +0200
> > >When you are doing a GetCapabilities, what is your URL?
> > >Do you add &service=WFS&request=GetCapabilities&version=1.0.0
> > >otherwise probably the default is the WMS capabilities and you miss
> > >"wms_title" METADATA for that. If you want to be shorter, use the more
> > >general ows_title and leave out wfs_title and wms_title.
> > >Best regards,
> > >Bart
> > >Postbus 270
> > >2600 AG  DELFT
> > > >>> Mehdi Kiman <oubinny at HOTMAIL.COM> 08/25/05 4:29 pm >>>
> > >Hi,
> > >I have a problem with my WFS server, i tried to configure it.
> > >My MapFile is correct :
> > >MAP
> > >NAME "Pays_nee_de_la_mer"
> > >DEBUG on
> > >SIZE 600 400
> > >STATUS ON
> > >EXTENT 310559.98 2147175.0 335547.03 2176659.97
> > >FONTSET "../data/fonts.txt"
> > >UNITS METERS
> > >SHAPEPATH "../data/data_map/"
> > >WEB
> > >   IMAGEPATH 'C:/tmp/ms_tmp/'
> > >   IMAGEURL  '/ms_tmp/'
> > >   METADATA
> > >       "wfs_title"                  "wfs Pays Ne de La Mer"
> > >       "wfs_onlineresource"
> > >"http://emir:8080/cgi-bin/mywfs.exe?config_wfs.map&"
> > >       "wfs_srs"                   "epsg:27582"
> > >       "wfs_feature_info_mime_type" "text/html"
> > >    END
> > >END
> > >LAYER
> > >     CONNECTIONTYPE OGR
> > >     CONNECTION "../data/data_map/Parcelles.TAB"
> > >	NAME "Parcelles"
> > >	TYPE POLYGON
> > >	STATUS ON
> > >	#STYLEITEM "AUTO"
> > >	CLASS
> > >		NAME "Parcelles"
> > >		TEMPLATE "ttt.html"
> > >		STYLE
> > >		COLOR 255 255 0
> > >		OUTLINECOLOR 0 0 2
> > >		END
> > >	END
> > >	METADATA
> > >	"wfs_title" "Parcelles"
> > >	END
> > >	PROJECTION
> > >    "init=epsg:27582"
> > >	END
> > >END
> > >And when i make a GetCapabilities, i have this kind of error for each
> >layer
> > ><!-- WARNING: Mandatory metadata '..._title' was missing in this
>context.
> > >What's wrong with my server ?
> > >Thanks
> > >Mehdi
