print option
Piero Cavalieri piero.cavalieri at HEIDI.IT
Thu Aug 25 11:22:35 EDT 2005
PdfLib isn't free. You have to buy a license if you want to remove the
banner. There should be also a Lite version, which as some limitations
respect full version (no .NET bindings for example). This version is free
under certain circustances (and don't have the banner).
If you can't use pdflib, in php manual, when talking about pdf, there
are links to other free pdflib libraries (of course you will have to
rewrite code from scratch). I think you could try them too, and then decide
what's the best option for you.
Cheers
  Piero
Carlos Eduardo Sibaja Salazar wrote:
>Thanks to everyone for your help about the print option.
>I'm using the example sent by Piero Cavalieri. It works fine but i have a
>problem with the library pdflib, because when i print a map, a message
>showing this "www.pdflib.com" is printed over the map crossing the page.
>I found this explanation in www.pdflib.com:
>"PDFlib, PDFlib+PDI, and PPS are distributed as one single binary package
>which is fully functional, but displays a demo stamp across all generated
>pages unless a valid license key is applied."
>I'm not sure if i have to buy the license key or there are some free
>options.
>Please tell me what i have to do.?
