Blank image being created in MS 4.6.0
Mike Boos
mboos at AUGSIGNALS.COM
Thu Aug 25 14:26:43 EDT 2005
I'm not sure. I assumed that because the map worked before in the older
version that the extent should match up - unless something has changed
in the way Mapserver handles things.
Mike
Fawcett, David wrote:
>Do you have an issue with your extent matching the projection specified in your layer?
>David.
>David Fawcett
>Minnesota Office of Environmental Assistance
>david.fawcett at moea.state.mn.us
>651.215.0200
>-----Original Message-----
>From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
>Behalf Of Mike Boos
>Sent: Thursday, August 25, 2005 1:02 PM
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: [UMN_MAPSERVER-USERS] Blank image being created in MS 4.6.0
>Hello
>I'm trying to upgrade our map server from version 4.1 to 4.6.0 and am
>facing some hurdles. The map files work fine in version 4.1, but are all
>generating blank white images for me in 4.6.0. From reading the mailing
>lists and the documentation, I can't seem to find what's wrong with the
>map files. Here's an example:
>#epsg:32611
>NAME AUG21234542.map
>SIZE 400 400
>EXTENT 0 0 576 432
>WEB
>TEMPLATE ../mapServerTemplateVis.html
>IMAGEPATH ""
>IMAGEURL ""
>END
>LAYER
>TYPE RASTER
>STATUS DEFAULT
>DATA "C:\inetpub\ftproot\input_images\AUG162454635.jpg"
>PROJECTION
>"init=epsg:32611"
>END
>TRANSPARENCY 100
>END
>END
>Does anyone know what changes I need to make to have the image appear on
>my map?
>Thanks
>Mike Boos
