Blank image being created in MS 4.6.0
Brent Fraser
bfraser at GEOANALYTIC.COM
Thu Aug 25 15:19:43 EDT 2005
Mike,
Well, this is getting interesting. In theory, your original map file
should work. Even though the coordinates you give are pixels, not world
coordinates, MapServer doesn't know that. I tried the following map file
with 4.6:
#epsg:32611
NAME AUG21234542.map
SIZE 400 400
EXTENT 0 0 576 432
WEB
TEMPLATE Template.html
IMAGEPATH ""
IMAGEURL ""
END
LAYER
TYPE RASTER
STATUS DEFAULT
DATA "test.jpg"
PROJECTION
"init=epsg:32611"
END
# TRANSPARENCY 100
END
END
This actually causes mapserv.exe to crash! And un-commenting the
TRANSPARENCY 100 stops the crashing. shp2img doesn't crash, but it spits
out a GIF stream to stdout even though I used "-o test.gif" for an output
file.
I'll have to step through this in the debugger....
Brent Fraser
GeoAnalytic Inc.
Calgary, Alberta, Canada
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Thursday, August 25, 2005 12:41 PM
Subject: Re: [UMN_MAPSERVER-USERS] Blank image being created in MS 4.6.0
> This is the output I get from gdalinfo:
> Driver: JPEG/JPEG JFIF
> Size is 576, 432
> Coordinate System is `'
> Corner Coordinates:
> Upper Left ( 0.0, 0.0)
> Lower Left ( 0.0, 432.0)
> Upper Right ( 576.0, 0.0)
> Lower Right ( 576.0, 432.0)
> Center ( 288.0, 216.0)
> Band 1 Block=576x1 Type=Byte, ColorInterp=Red
> Band 2 Block=576x1 Type=Byte, ColorInterp=Green
> Band 3 Block=576x1 Type=Byte, ColorInterp=Blue
> I tried adding projection information to the map, no result.
> Mike
> Brent Fraser wrote:
> >Mike,
> > You don't have a PROJECTION definition for your map (the target image
to
> >be created by mapserver). And your EXTENT coordinates look like pixel
> >values instead of world coordinates (e.g. meters or degrees).
> > Try changing
> >EXTENT 0 0 576 432
> > to
> >EXTENT 300000 5000000 700000 6000000
> > or better yet, get the world extents of your input jpg file by using:
> > gdalinfo C:\inetpub\ftproot\input_images\AUG162454635.jpg
> >You might want to add
> >PROJECTION
> > "init=epsg:32611"
> >END
> >after the EXTENT entry as well.
> >Brent Fraser
> >GeoAnalytic Inc.
> >From: "Mike Boos" <mboos at AUGSIGNALS.COM>
> >Sent: Thursday, August 25, 2005 12:17 PM
> >>Thanks, but neither changing the colour nor the transparency did
anything.
> >>Mike
> >>Hydock,Shaun T. wrote:
> >>>I ran into something similar, adding a class to set the color in the
> >>>layer generated a viewable image for me:
> >>> CLASS
> >>> COLOR 0 100 200
> >>> END
> >>>Good luck!
> >>>Shaun
> >>>-----Original Message-----
> >>>From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
On
> >>>Behalf Of Mike Boos
> >>>Sent: Thursday, August 25, 2005 2:02 PM
> >>>To: MAPSERVER-USERS at LISTS.UMN.EDU
> >>>Subject: [UMN_MAPSERVER-USERS] Blank image being created in MS 4.6.0
> >>>Hello
> >>>I'm trying to upgrade our map server from version 4.1 to 4.6.0 and am
> >>>facing some hurdles. The map files work fine in version 4.1, but are
all
> >>>generating blank white images for me in 4.6.0. From reading the mailing
> >>>lists and the documentation, I can't seem to find what's wrong with the
> >>>map files. Here's an example:
> >>>#epsg:32611
> >>>SIZE 400 400
> >>>EXTENT 0 0 576 432
> >>>WEB
> >>>TEMPLATE ../mapServerTemplateVis.html
> >>>IMAGEPATH ""
> >>>IMAGEURL ""
> >>>END
> >>>LAYER
> >>>TYPE RASTER
> >>>STATUS DEFAULT
> >>>DATA "C:\inetpub\ftproot\input_images\AUG162454635.jpg"
> >>>PROJECTION
> >>>"init=epsg:32611"
> >>>END
> >>>TRANSPARENCY 100
> >>>END
> >>>END
> >>>Does anyone know what changes I need to make to have the image appear
on
> >>>my map?
> >>>Thanks
> >>>Mike Boos
