Mapserver demo crash
Matt Garrish
matthew.garrish at SYMPATICO.CA
Fri Aug 26 09:41:22 EDT 2005
I'm just getting started with mapserver and was hoping to be able to play
around with the demo (http://mapserver.gis.umn.edu/dload.html). I'm
reasonably certain that my system (XP Pro SP2) is configured correctly,
because I can run some of the other simple examples I've found on the
Mapserver home page (I downloaded the 4.4.1 binary and set it up according
to the readme file). When I tried to run the demo (from the index.html
page), however, IIS crashed with a 502 error, so I went to the command line
and tried the following:
C:\Inetpub\Scripts>mapserv
"QUERY_STRING=map=c:/inetpub/wwwroot/workshop/itasca.
map&layer=lakespy2&layer=dlgstln2&zoomsize=1&program=http://localhost/cgi-bin/ma
pserv.exe&root=http://localhost/workshop&map_web_imagepath=c:/inetpub/wwwroot/tm
p&map_web_imageurl=http://localhost/tmp&map_web_template=itasca_basic.html"
As soon as I run the command, however, an error window pops up with the
following error signature:
AppName: mapserv.exe AppVer: 0.0.0.0 ModName: ntdll.dll
ModVer: 5.1.2600.2180 Offset: 00018fea
which I have to assume is the cause of the 502 error.
Has anyone run into this problem before? Or know what the cause might be? Or
know if I'm just doing something wrong? (If you don't have XP or can't
reproduce the problem I can post the stack dump.)
Thanks in advance,
Matt
