Mapserver demo crash
Ethan Alpert
ealpert at DIGITALGLOBE.COM
Fri Aug 26 10:48:00 EDT 2005
I'm not a windows user but the most common problem when mapserv runs
fine at the command line but dies running in the webserver space is it
can't find one or more shared library. Check the IIS's equivalent of
LD_SEARCH_PATH.
-e
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Matt Garrish
Sent: Friday, August 26, 2005 7:41 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Mapserver demo crash
I'm just getting started with mapserver and was hoping to be able to
play
around with the demo (http://mapserver.gis.umn.edu/dload.html). I'm
reasonably certain that my system (XP Pro SP2) is configured correctly,
because I can run some of the other simple examples I've found on the
Mapserver home page (I downloaded the 4.4.1 binary and set it up
according
to the readme file). When I tried to run the demo (from the index.html
page), however, IIS crashed with a 502 error, so I went to the command
line
and tried the following:
C:\Inetpub\Scripts>mapserv
"QUERY_STRING=map=c:/inetpub/wwwroot/workshop/itasca.
map&layer=lakespy2&layer=dlgstln2&zoomsize=1&program=http://localhost/cg
i-bin/ma
pserv.exe&root=http://localhost/workshop&map_web_imagepath=c:/inetpub/ww
wroot/tm
p&map_web_imageurl=http://localhost/tmp&map_web_template=itasca_basic.ht
ml"
As soon as I run the command, however, an error window pops up with the
following error signature:
AppName: mapserv.exe AppVer: 0.0.0.0 ModName: ntdll.dll
ModVer: 5.1.2600.2180 Offset: 00018fea
which I have to assume is the cause of the 502 error.
Has anyone run into this problem before? Or know what the cause might
be? Or
know if I'm just doing something wrong? (If you don't have XP or can't
reproduce the problem I can post the stack dump.)
Thanks in advance,
Matt
