Donut Symbol.
Blammo
bob.basques at CI.STPAUL.MN.US
Fri Aug 26 12:46:58 EDT 2005
Jeff,
I tried that already.
What I'm basically after is a sysmbol that is a empty circle with a
thickness aplied to the line. Ideally it would be a symbol like
anyother that I could apply a COLOR and OUTLINECOLOR to.
Paco's idea of the close "u" shap would work if I didn't need to outline it.
I also ran into another slight problem as well (may Paco has some ideas
about this too.)
I was trying to use this symbol as a distance measuring tool. but
seemed to run into a snag with a size limit. I couldn't get the symbol
to go over a certain pixel size. The circle is supposed to represent
a distance buffer in miles (ground units).
If I zoom in too close, the symbol won't get any larger than a certain
size, about 500 pixels I would guess. I actually have three of these
symbols stacked on top of each other for different distances. But the
size of the symbol grow as I zoom in, but once I hit this max pixel
size, the sysbol stop growing at this approx 500 pixel size.
Thanks
bobb
Jeff Portwine wrote:
>I haven't tried this , so it may not work, I've always used filled in
>shapes.. but couldn't you just use a non-filled in circle:
>SYMBOL
> NAME "circle"
> TYPE ellipse
> FILLED false
> POINTS
> 1 1
> END
>END
>and then set its size appropriately? I'm not sure if there is a good way
>to affect the thickness though, other than stacking several of them with
>varying sizes.
>-Jeff
>----- Original Message -----
>From: "Bob Basques" <bob.basques at CI.STPAUL.MN.US>
>To: <MAPSERVER-USERS at LISTS.UMN.EDU>
>Sent: Thursday, August 25, 2005 5:39 PM
>Subject: [UMN_MAPSERVER-USERS] Donut Symbol.
>>Does anyone know of a good way to make a donut symbol.
>>I need to be able to resize a symbol that is basically a donut. Where the
>>donut part is semi-opaque, and the center is open. It's basically a
>>min/max distance from a point overlay. I have the dynamic handing off of
>>the sizing handled already, but haven't figured out a good way to make a
>>filled donut symbol.
>>I did mange to make a stacked symbol, but I would really like to have the
>>center no be filled in, only the area between the MIN/MAX distance from
>>the point picked.
>>Thanks
>>bobb
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050826/252c64ce/attachment.html
