Calling all PROJ4 genuises
Tyler Mitchell
tylermitchell at SHAW.CA
Mon Aug 29 15:59:05 EDT 2005
> Tyler, thank you *very* much. I'll have to try to
> parse through that and learn the parameters better.
> My cs2cs is from the proj-4.4.9 release. I'm getting
> an error for the 2nd init:
> cs2cs +init=epsg:4326 +to +init=102718
Oops, I should have written "+init=epsg:102718"
When +init=epsg:<number> is used, it looks up all the parameters from a proj4 text file called 'epsg'. Find that on your system and then add these two lines at the end:
# NAD 1983 StatePlane New York Long Island FIPS 3104
Feet <102718> +proj=lcc +lat_1=40.66666666666666 +lat_2=41.03333333333333 +lat_0=40.16666666666666 +lon_0=-74 +x_0=300000 +y_0=0 +ellps=GRS80 +datum=NAD83 +to_meter=0.3048006096012192 no_defs <>
Then you should be able to use the syntax I provided. Hope that helps!
Tyler
