WFS and Oracle
Fernando Simon fsimon at UNIVALI.BR
Tue Aug 30 13:05:31 EDT 2005
Hi Hubb,
    Since friday I worked in the maporaclespatial.c and found some
problems: possible segmentation faults with handlers, memory errors (as
Silke reported); and I updated it for a better multi-thread support.
    Now I'm testing the code with the updates, and after this I will
commit the code in the cvs branch.
    I believe that you can use the Hobu bin without problems.
    Thanks again.
Fernando Simon
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada - Brazil
http://www.univali.br/g10 - UNIVALI/CTTMAR
Huub Fleuren wrote:
> I' m sorry to say that the trick to use an upgraded vc6sp6 .\Common
> and .\vc98 did not yet do the trick.
> I'm thinking dependencies now. I will rebuild from scratch.
> A comforting thought is that we can use Howard Butler's fully featured
> Oracle92 compile.
> http://hobu.stat.iastate.edu/mapserver/
> So, I'll keep on swimming for a while.
> Thank you for the responses
> Regards, Huub
> Huub Fleuren wrote:
>> oke
>> results on monday.
>> Regards, Huub
>> Bart van den Eijnden wrote:
>>> Huub,
>>> you need to compile mapserv with VC6, SP3 or SP4 minimal (one of the
>>> two, I can't remember exactly). Otherwise you get crashes on
>>> GetFeatureInfo or GetFeature with maporaclespatial. VC7 also does
>>> the trick.
