Problem with Perl script and image maps
Lowell Filak
lfilak at MEDINACO.ORG
Tue Aug 30 13:11:36 EDT 2005
The following message was sent by Robert Parsons
<rparsons at TAPPUBLISHING.COM> on Mon, 29 Aug 2005 12:38:01 -0500.
> Can anyone offer any insight for this problem? I get "Segmentation Fault"
> any time I attempt to call $map->draw() for any map that is set to output
> via the "imagemap" driver. It's quite easy for me to reproduce and it
even
> happens when simply opening a .map file from within a perl script. For
> example, this simple script throw a Seg Fault during the draw().
> #!/usr/bin/perl
> use mapscript;
> my $msmap = mapscript::mapObj->new('test.map');
> my $image=$msmap->draw();
> $image->save('test');
> Here's the test.map file:
> MAP
> EXTENT -14023070.10627 1859777.927636 -7135266.299414 7255753.260196
> IMAGECOLOR 0 0 0
> IMAGETYPE imagemap
> SHAPEPATH "/wxhub/common/shapefiles"
> SIZE 868 680
> STATUS ON
> UNITS METERS
> NAME "TEST"
> OUTPUTFORMAT
> NAME "imagemap"
> MIMETYPE "text/html"
> DRIVER "imagemap"
> END
> PROJECTION
> "proj=merc"
> "lat_0=0"
> "lon_0=0"
> "datum=WGS84"
> END
> WEB
> IMAGEPATH ""
> IMAGEURL ""
> METADATA
> END
> QUERYFORMAT text/html
> END
> LAYER
> DATA "statesp020"
> METADATA
> END
> NAME "mylayer"
> PROJECTION
> "proj=latlong"
> END
> SIZEUNITS PIXELS
> STATUS ON
> TOLERANCEUNITS PIXELS
> TYPE POLYGON
> UNITS METERS
> CLASS
> METADATA
> END
> STYLE
> ANGLE 360
> COLOR 255 255 255
> SIZE 1
> SYMBOL 0
> END
> END
> END
> END
> The same code will work fine if I change the .map file to output to a GIF
> instead of an imagemap.
Robert,
There appears to be something wrong with the mapfile. Running shp2img on
the mapfile produces the same error (for imagemap)/success (for gif).
At this point I'm not sure what the mapfile requires (particularly in
the 'style' section) where the 'imagemap' seems to be blowing up.
Lowell
