oracle x mapserver
Frank Warmerdam
fwarmerdam at GMAIL.COM
Tue Aug 30 13:49:35 EDT 2005
On 8/30/05, Davi Duchovni <duchovni at gmail.com> wrote:
> please,
> i´m wonder if i can work with mapserver and oracle, not oracle spatial.
> Is there any way to visualize points stores in the base in two columns
> diferentes, one represent the X and the other one represent the Y.
> Both number are non-spatial.
Davi,
You could just connect to Oracle by ODBC and use the OGR VRT
mechanism to treat the pair of columns as x/y point locations. There
is discussion on how to do this in the wiki I believe.
You could also use the OGR OCI driver to access a non-spatial
oracle table but I think you would need to explicitly list the target
table in the datasource since normally only spatial tables are treated
as layers.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
