Mode browse works but mode map and wms server do not?
Miller Joseph
miller_joseph at BAH.COM
Tue Aug 30 17:30:38 EDT 2005
Problem:
Mapserver 4.6 on IIS 6 (Windows 2003 Server)works in browse mode but
when I need it to stream png files, either in mode=map or as a wms
server, the browser only shows a broken link. In addition, the streamed
output jpg files look extremely distorted, but it's definitely not a
projection issue. (BTW, I had exactly the same issues with Apache on
this machine)
I have built mapserver 4.6 with the following capabilities:
MapServer version 4.6.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG
SUPPORTS=P
ROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVE
R SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI INPUT=SDE
INPUT=OGR I
NPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
My map file is below(the urls,username, and password have been altered):
MAP
NAME GISR
STATUS ON
UNITS DD
IMAGETYPE PNG24
EXTENT -179 -90 179 83
Size 400 300
IMAGECOLOR 255 255 255
SHAPEPATH "d:\mapserver\"
WEB
LOG "d:\mapserver\logmapserver.txt"
IMAGEPATH "d:\mapserver\"
IMAGEURL "http://myserver.com/mapserver/"
TEMPLATE "d:\mapserver\test1.htm"
METADATA
"wms_title" "GISR WMS Server"
"wms_onlineresource"
"http://myserver.com/mapserver/mapserv.exe?map=test1.map&"
"wms_srs" "EPSG:4326"
END # of metadata
END # of Web
PROJECTION
"init=epsg:4326"
END # of projection
LAYER
NAME World_Countries
METADATA
"wms_title" "World_Countries"
END #of metadata
TYPE POLYGON
STATUS DEFAULT
CONNECTION "10.0.0.19,port:5151,sde,username,password"
CONNECTIONTYPE SDE
DATA "ACSIM.CNTRY02,SHAPE,SDE.DEFAULT"
PROJECTION
"init=epsg:4326"
END #of projection
CLASS
NAME "The Upper Great Lakes States"
STYLE
COLOR 232 232 232
OUTLINECOLOR 32 32 32
END #of style
END #of class
END #of first sde layer
END #of MAP
Any ideas?
Joe Miller
