Sat-picture - no colors!?
Leopold Schefcik (MULTIMEDIAPLAN.AT)
leopold.schefcik at MULTIMEDIAPLAN.AT
Wed Aug 31 04:58:45 EDT 2005
hi,
My sat-picture has about 16,7 Mio colors but in the client only about 256
grew-colors.
I tried to change PNG to PNG24, but it's still b/w.
When I change IMAGEMODE PC256 to MAGEMODE "png24" or IMAGEMODE png24 my
GetCapabilitiesRequest isn't accepted any more.
Some other idea to get the colors displayed.
best regards - Leopold
The map-file:
MAP
NAME "mmp_wms"
STATUS ON
EXTENT 71473.4670152 40074.0096694 1251326.533 923294.99034
SIZE 800 600
SHAPEPATH "./data"
SYMBOLSET "./etc/symbols.sym"
FONTSET "./etc/fonts.txt"
IMAGECOLOR 255 255 226
UNITS METERS
WEB
MINSCALE 2e+006
MAXSCALE 5e+007
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
"WMS_SRS" "EPSG:31287 EPSG:4326 EPSG:31466 EPSG:31467"
"wms_title" "Centrope WMS sat Viertel NW"
"wms_abstract" "Satellitenbild Centrope Region - Viertel NW"
END
END
QUERYMAP
STATUS ON
SIZE -1 -1
COLOR 255 0 0
STYLE HILITE
END
PROJECTION
"init=epsg:31287"
END
LEGEND
STATUS ON
IMAGECOLOR 255 255 255
POSITION UL
KEYSIZE 18 12
KEYSPACING 5 5
TEMPLATE
"C:/ms4w/apps/maplab-2.2/htdocs/mapbrowser/legend_template.html"
LABEL
TYPE BITMAP
FONT "fritqat-italic"
SIZE MEDIUM
OFFSET 0 0
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 89
PARTIALS TRUE
FORCE FALSE
END
END
SCALEBAR
STATUS ON
COLOR 255 255 255
OUTLINECOLOR 0 0 0
BACKGROUNDCOLOR 0 0 0
UNITS KILOMETERS
INTERVALS 5
SIZE 300 5
STYLE 0
POSITION LL
LABEL
TYPE BITMAP
SIZE SMALL
OFFSET 0 0
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 0
PARTIALS TRUE
FORCE FALSE
END
END
OUTPUTFORMAT
NAME "png24"
MIMETYPE "image/png24"
DRIVER "GD/PNG24"
EXTENSION "png24"
IMAGEMODE PC256
TRANSPARENT OFF
END
LAYER
NAME "Centrope_Viertel_NW"
STATUS ON
DATA "testausschnitt_viertel.tif"
TYPE RASTER
UNITS METERS
SIZEUNITS PIXELS
MINSCALE 1
MAXSCALE 100000000
TOLERANCE 0
TOLERANCEUNITS PIXELS
METADATA
"wms_title" "Centrope_Viertel_NW"
"DESCRIPTION" "Centrope_Viertel_NW"
END
CLASS
STYLE
SYMBOL 0
SIZE 1
MINSIZE 1
MAXSIZE 100
END
END
END
END
-----Ursprüngliche Nachricht-----
Von: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Im
Auftrag von Michael Schulz
Gesendet: Dienstag, 30. August 2005 13:40
An: MAPSERVER-USERS at LISTS.UMN.EDU
Betreff: Re: [UMN_MAPSERVER-USERS] 3 little Questions
Hi Leopold,
Q1: you will need to use a style that uses a vector symbol, e.g.
SYMBOL
NAME "circle"
TYPE ellipse
FILLED true
POINTS
1 1
END
END
then you can use the SIZE parameter in the mapfile on that symbol.
Q2: Are you sre mapserver finds your shapefile in ./data? Did you try to
use an absolute path to your data directory?
Q3: Not sure, but did you try using a 24-bit output format, e.g. png24 ?
Cheers, Michael
Leopold Schefcik (MULTIMEDIAPLAN.AT) schrieb:
> Hi list,
> Question 1 (of 3):
> maybe a simple question: How in general can I change the width of a
> line(vectordata)?
> Maybe not with 'SIZE' because regardless of which SIZE 1 or SIZE 50 or
SIZE
> 100 there is allways a fine line.
> CLASS
> NAME "XC_Rivers"
> STYLE
> SYMBOL 0
> COLOR 72 0 254
> SIZE 100
> MINSIZE 1
> MAXSIZE 100
> END
> END
> Question 2 (of 3):
> I'd like to show a layer (polygones) with the population density in 5
clases
> (in different colors).
> I made the map file like in centrope_wms_bevdichte_2.map in the
attachement
> is shown. e.g. with this:
> CLASS # Low Density
> MAXSCALE 120000
> MINSCALE 500
> EXPRESSION ([Bev_class]=1) #if it is a string ('[FIELD]'='value')
> SYMBOL 1
> COLOR 248 147 147
> SIZE 1
> END
> CLASS # High Density
> MAXSCALE 120000
> MINSCALE 500
> EXPRESSION ([Bev_class]=2)
> SYMBOL 1
> COLOR 249 36 36
> SIZE 1
> END
> But I only get this message:
> msDrawMap():Failed to draw layer named `Bev_Density'.
> Someone has an idea about this?
> Question 3 (of 3):
> I have a satellite tif for my background. It is in color. But in my client
> it is only shown in black and white.
> Do I have to change some command line here?
> (map file for satellite picture is also in attachement:
> centrope_wms_sat.map)
> Thanks a lot for everybody, who is trying to help me here a little bit.
> Best regards,
> Leopold
Michael Schulz mschulz at webgis.de
in medias res Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66 Tel +49 (0)761 556959-5
79108 Freiburg Fax +49 (0)761 556959-6
www.webgis.de / www.zopecms.de
NEU ++ UMN MapServer Hosting ++ http://www.webgis.de ++ NEU
