mapserver use of epsg
Piero Cavalieri
piero.cavalieri at HEIDI.IT
Wed Aug 31 11:48:00 EDT 2005
On Win, I have env variable:
PROJ_LIB C:\proj\nad
and proj is in C: (C:\proj\)
P.
Don Isgitt ha scritto:
> Hi,
> I am trying to use the mapserver Flash Maps extension, and have managed to
compile and link everything (I think.). But when running the demo, i get the
following error:
> msProcessProjection(): Projection library error. no system list, errno: 2
> which I assume is because it cannot find the projection data. I have
proj-4.4.9. Where does the epsg file belong? The projection that the map
file is asking for is in the epsg file. I wandered through the mapserver
reference manual, and several other documents, but could not find the
answer. Just to try something, I put a copy in the directory with the map
file, but no joy. Perhaps some environment variable?
> Thank you for any help.
> Don
