mapserver use of epsg
Don Isgitt
djisgitt at SOUNDENERGY.COM
Wed Aug 31 14:15:40 EDT 2005
Jeff McKenna wrote:
> You can also set this variable in the mapfile, with the MAP object's
> "CONFIG" parameter
> (http://mapserver.gis.umn.edu/doc46/mapfile-reference.html#map).
> jeff
> Piero Cavalieri wrote:
>> On Win, I have env variable:
>> PROJ_LIB C:\proj\nad
>> and proj is in C: (C:\proj\)
>> P.
>> Don Isgitt ha scritto:
>>> Hi,
>>> I am trying to use the mapserver Flash Maps extension, and have
>>> managed to
>> compile and link everything (I think.). But when running the demo, i
>> get the
>> following error:
>>> msProcessProjection(): Projection library error. no system list,
>>> errno: 2
>>> which I assume is because it cannot find the projection data. I have
>> proj-4.4.9. Where does the epsg file belong? The projection that
>> the map
>> file is asking for is in the epsg file. I wandered through the
>> mapserver
>> reference manual, and several other documents, but could not find the
>> answer. Just to try something, I put a copy in the directory with the
>> map
>> file, but no joy. Perhaps some environment variable?
>>> Thank you for any help.
>>> Don
> Thank you, Piero and Jeff. Your answers resolved that problem, and
> allowed me to get to the next one!
Don
