MapServer CGI : Url encoding of negative values for mapext parameter ?
Ed McNierney ed at TOPOZONE.COM
Fri Dec 2 10:42:16 EST 2005
Laurent -
Could you give us an example of a URL that does NOT work for you?
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Laurent Jégou
Sent: Friday, December 02, 2005 8:21 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] MapServer CGI : Url encoding of negative values for mapext parameter ?
Hi, a simple question this time :
I'm generating 36x18 ten degrees squares maps with (UMN genuine) MapServer, using php to generate <img src=" MapServer cgi calls. So i use the cgi variable mapext=. Example of sch an url :
http://localhost/cgi-bin/mapserver.exe?mode=map&map=my_path_to_mapfile.map&mapext=10+40+20+50
But it's not working when negative values occurs, and since the spatial reference is lat/long wgs84, there are some negatives...
Anyone can help me to find the right url syntax for the mapext paramater ?
Laurent Jégou
IGE Cartographe
UTM - Dépt. Géographie
31058 TOULOUSE Cedex 9 - 05.61.50.43.89
http://www.univ-tlse2.fr/geoprdc
http://www.geotests.net/blog
