How do I embed any text onto the map
Daryl Herzmann akrherz at IASTATE.EDU
Fri Dec 2 11:27:38 EST 2005
Hi Steve,
> The problem you'll run into is that inline pixel coordinates are
> absolute so they really only work with one image size. (except for the
> UL corner which is always 0,0) The only solution there is to either have
> 1 mapfile for each image size you need. You could muck with the
> coordinates at runtime possibly too.
> Ideally we'd allow relative pixel coordinates some like:
> FEATURE
>  RELATIVETO LR
>  POINTS -50 -50 END
> END
> Which would give you a point just inside the lower right-hand corner,
> but alas it has not been implemented. (not a bad idea and not that hard-
> I'll file a bug now).
Good idea.  I see you have added this bug:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1547
I would like to see the use of values that range from 0 to 1 to specify
the location.  So if you wanted the middle of the image, you would use 0.5
0.5 .  Perhaps the REALTIVETO could be IMGSIZE or something like that.  I
have added my comment to the bug...
thanks,
    daryl
   * Daryl Herzmann (akrherz at iastate.edu)
   * Program Assistant -- Iowa Environmental Mesonet
   * http://mesonet.agron.iastate.edu
