Projection & raster questions
Stephen Davies
sdc at SDC.COM.AU
Sat Dec 3 01:35:25 EST 2005
I have resolved this issue by rebuilding GEOS, GDAL and mapserv.
It now all works beautifully.
Cheers,
Stephen
On Thur, 1 Dec 2005 05:00 pm, you wrote:
> I have an application which is heavily based on the DHTML rubber band
> sample in the MapServer tutorial. That is, it used two divs to present
> a main map and a reference map with mapserv?mode=map commands.
> (MapServer version 4.6.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=GEOS INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS
> INPUT=SHAPEFILE)
> The data involved is stored in a PostGIS database as lat/long
> coordinates and is (currently) projected into the map with proj=eqc
> lon_0=xxx where xxx is calculated dynamically as the centre of the
> initial map extent.
> With the attached map1.map mapfile this works very well and users can
> zoom, pan and query from the main map and pan from the reference map
> with the correct results (though the area of interest square on the
> reference map is sometimes marginally out - particularly for very
small
> map extents aganst relatively large reference maps).
> The extent for the initial main map is given via the URL in the form:
&mapext=139.357482910156+-34.3308868408203+139.380233764648+-34.3129386901855
> That is, long/lat (calculated dynamically from other input) and the
> UNITS are meters.
> The values plpl, exex and cidcid are edited to realvalues before
> invoking mapserv. plpl is the calculated central meridian, cidcid is
> the current user ID and exex is the extent of the reference map IN
> METRES!
> This latter extent is calculated from lat/long values using proj:
> proj +proj=eqc +lon_0=$central (where $central is the same value as
plpl
> above)
> As I say, the above all works exactly as I want - provided the above
> projection and extent rules are followed.
> However, I now want to add the raster layer and am having difficulty
> getting the new layer to align with the rest.
> The raster file is an ECW.
> Driver: ECW/ERMapper Compressed Wavelets
> Size is 82560, 70380
> Coordinate System is:
> GEOGCS["GEOCENTRIC DATUM of AUSTRALIA",
> DATUM["GDA94",
> SPHEROID["GRS80",6378137,298.257222101]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]]
> Origin = (112.500000,-8.903313)
> Pixel Size = (0.00050000,-0.00050000)
> Corner Coordinates:
> Upper Left ( 112.5000000, -8.9033134) (112d30'0.00"E, 8d54'11.93"S)
> Lower Left ( 112.5000000, -44.0933134) (112d30'0.00"E, 44d 5'35.93"S)
> Upper Right ( 153.7800000, -8.9033134) (153d46'48.00"E,
8d54'11.93"S)
> Lower Right ( 153.7800000, -44.0933134) (153d46'48.00"E, 44d
5'35.93"S)
> Center ( 133.1400000, -26.4983134) (133d 8'24.00"E,
26d29'53.93"S)
> Band 1 Block=82560x1 Type=Byte, ColorInterp=Red
> Overviews: arbitrary
> Band 2 Block=82560x1 Type=Byte, ColorInterp=Green
> Band 3 Block=82560x1 Type=Byte, ColorInterp=Blue
> To test the ECW raster facility, I created a test map file (attached
as
> map2.map).
> The only ways that I could get the image displayed were to specify the
> projection as epsq:4263 and the extent as lat/long or the projection
as
> eqc and the extent in meters relative to 0,0 at top left despite the
> image georef stuff all being in lat/long (why is this??).
> Neither of these combinations will work in the existing application
(as
> the rubber band and reference map interfaces require metres and a
> proper geographic extent) so I went back to square one with that app
> and tried again to specify the map extent in metres.
> I used proj to convert the lat/long extent into metres and tried to
> generate a map. At first it looked as if the map was blank but then I
> randomly panned around and discovered that the data was actually there
> but off the map. Apparently, the extent values out of the proj command
> differ quite significantly from the same values generated within
> mapserv????
> For example, proj gave me values of -1282.08, -3821696.8 &
> 1250.54,-3819699 while mapserv gave -1336.4, -3802151 & 1351.1,
> -3799464 for approximately the same piece of space.
> So, I now have two problems:
> 1. how to calculate the correct extent values for the base app and
> 2. how to get the raster layer to align with the rest (that is with
the
> same extent as the rest rather than the 0,0-based one).
> TIA,
> Stephen avies
> This email is for the person(s) identified above, and is confidential
to
> the sender and the person(s). No one else is authorised to use or
> disseminate this email or its contents.
> Stephen Davies Consulting Voice: 08-8177
1595
> Adelaide, South Australia. Fax: 08-8177
0133
> Computing & Network solutions. Mobile:0403 0405
83
This email is for the person(s) identified above, and is confidential to
Stephen Davies Consulting Voice: 08-8177 1595
Adelaide, South Australia. Fax: 08-8177 0133
Computing & Network solutions. Mobile:0403 0405 83
Name: not available
Desc: signature
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051203/aa6470ed/attachment.bin
