Compilation issues with gd.h on Linux 64bit
Xin crazygecko at GMAIL.COM
Mon Dec 5 04:56:22 EST 2005
Hi again,
I'm still having difficulties with this.  I don't believe the problem lies
with the server being 64bit as I've read other people compile successfully
on them.
I've searched the archives and there seems to be a few posts concerning this
can't find gd.h problem, but no fixes.
Any advice is welcome.
Cheers,
Xin
On 02/12/05, Xin <crazygecko at gmail.com> wrote:
> I'm attemping to compile mapserver on our web hosting server, which are
> cool enough to allow this.  But I'm having some problems.
> First off, it says it can't find gd.h.  I've included the compilation
> command used and output at the end.  I've checked and gd does exist in
> /usr/lib and /usr/include, and pointed to /usr to no avail.  I also tried
> compiling gd myself.  Gd was compiled successfully, but mapserver can't see
> it.
> I then called a friend who's with the same hosting company and managed to
> compile mapserver successfully.  He told me he didn't have any issues as it
> was on a older, 32 bit machine, and the server I'm on is 64bit.  Is this the
> issue?  Or am I just doing something stupid.
> I'm very grateful for any advice.
> Cheers,
> Xin
> configure: WARNING: you should use --build, --host, --target
> checking for 2-gcc... no
> checking for gcc... gcc
> checking for C compiler default output file name... a.out
> checking whether the C compiler works... yes
> checking whether we are cross compiling... no
> checking for suffix of executables...
> checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes
> checking whether gcc accepts -g... yes
> checking for gcc option to accept ANSI C... none needed
> checking for 2-g++... no
> checking for 2-c++... no
> checking for 2-gpp... no
> checking for 2-aCC... no
> checking for 2-CC... no
> checking for 2-cxx... no
> checking for 2-cc++... no
> checking for 2-cl... no
> checking for 2-FCC... no
> checking for 2-KCC... no
> checking for 2-RCC... no
> checking for 2-xlC_r... no
> checking for 2-xlC... no
> checking for g++... g++
> checking whether we are using the GNU C++ compiler... yes
> checking whether g++ accepts -g... yes
> checking for 2-ranlib... no
> checking for ranlib... ranlib
> checking for flex... flex
> checking for yywrap in -lfl... yes
> checking lex output file root... lex.yy
> checking whether yytext is a pointer... yes
> checking for bison... bison -y
> checking if compiler supports -R... no
> checking if compiler supports -Wl,-rpath,... yes
> checking for exp in -lm... yes
> checking for __gxx_personality_v0 in -lstdc++... yes
> checking how to run the C preprocessor... gcc -E
> checking for egrep... grep -E
> checking for ANSI C header files... yes
> checking for strcasecmp... yes
> checking for strncasecmp... yes
> checking for strdup... yes
> checking for strlcat... no
> MapServer Version from map.h: '4.6.1'
> configure: checking where FreeType 2.x is installed...
>         using libfreetype from -L/usr/lib64 -Wl,--rpath -Wl,/usr/lib64
> -lfreetype -lz
> checking for FT_Init_FreeType in -lfreetype... yes
>         using libfreetype -lfreetype from system libs.
> configure: checking where Zlib is installed...
>         using runtime libz from -L/lib64 -lz
> configure: checking where PNG is installed...
>         using libpng from -L/lib64 -lpng
> configure: checking whether we should include JPEG support...
> checking for jpeg_read_header in -ljpeg... yes
>         using libjpeg from system libs.
> configure: checking where libXpm is installed...
> checking for XpmFreeXpmImage in -lXpm... no
>         XPM (libXpm) library cannot be found, possibly needed for GD
> configure: checking where libiconv is installed...
> checking for iconv_open in -lc... yes
> checking for libiconv_open in -liconv... no
>         using libiconv from system libs.
>         libiconv found. Enabling internationalization (-DUSE_ICONV)
> configure: checking for GD 2.0.16 or higher...
> checking for gdFontCacheSetup in -lgd... no
> configure: checking whether GD needs libiconv...
> configure: error: Could not find gd.h or libgd.a/libgd.so in /usr.  Make
> sure GD 2.0.16 or higher is compiled before calling configure. You may
> also get this error if you didn't specify the appropriate location for one
> of GD's dependencies (freetype, libpng, libjpeg or libiconv).
> [~/dev/mapserver- 4.6.1]# whereis gd
> gd: /usr/include/gd.h
> [~/dev/mapserver-4.6.1]# ls /usr/include/gd.*
> /usr/include/gd.h
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051205/7c4c516c/attachment.html
