Fwd: [UMN_MAPSERVER-USERS] Compilation issues with gd.h on Linux 64bit
Xin crazygecko at GMAIL.COM
Mon Dec 5 13:00:35 EST 2005
Daniel,
Thanks for the interest.
I've fixed the gd problem now.  Commented out a couple if/else statements in
configure.in so that $GD_LIB is set to /usr/lib64 and $CD_INCLUDE to
/usr/include no matter what.    The 'autoconf -o configure2 configure.in' to
produce the configuration script.  This ran fine!  Compiled ok untill it
complained about no xpm.
That seems to have solved it for the gd problem.  Perhaps a overkill, who
knows.  I'll post the exact steps so it may help others.
Does anyone know where this xpm might be kept and what it might be called?
I assumed it'd be called libXpm.so and be in /usr/lib, /usr/lib64, but it
wasn't in there.  I'm going to have a go at compiling it now.
Cheers,
Xin
---------- Forwarded message ----------
From: Daniel Morissette <dmorissette at dmsolutions.ca>
Date: 05-Dec-2005 17:45
Subject: Re: [UMN_MAPSERVER-USERS] Compilation issues with gd.h on Linux
64bit
To: Xin <crazygecko at gmail.com>
Cc: MAPSERVER-USERS at lists.umn.edu
Xin wrote:
>     configure: error: Could not find gd.h or libgd.a/libgd.so in /usr.
>     Make sure GD 2.0.16 or higher is compiled before calling configure.
>     You may also get this error if you didn't specify the appropriate
>     location for one of GD's dependencies (freetype, libpng, libjpeg or
>     libiconv).
Do you have a libgd.a or libgd.so, if yes then where is it located?
Maybe we need to look in some lib64 directories? Also, what did you pass
as arguments to configure?
Daniel
  Daniel Morissette               dmorissette at dmsolutions.ca
  DM Solutions Group              http://www.dmsolutions.ca/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051205/9b93c09e/attachment.html
