R éf. : Re: [UMN_MAPSERVER-USERS] [Image] world map
Aniruddha S. Khadkikar as.khadkikar at NCL.RES.IN
Mon Dec 5 23:26:06 EST 2005
Hi Benjamin,
You are welcome. Also check out the UNEP link sent earlier by Laurent
Jégou. I found quite a few shapefiles that I did not have. Thanks Laurent.
You can download the SRTM data for Europe and render it using Microdem
or any other software and export it as a Geotiff to use as a backdrop.
This is essentially a DEM. The link is:
http://seamless.usgs.gov/
Else if you want satellite data, free, you may like to have a look at:
https://zulu.ssc.nasa.gov/mrsid/
The above data is in mrsid format. you can export it as jpeg. But you
will have to geocode it perhaps for your projection. If you are using
UTM zones, then you may need to have your other shapefiles which may be
in WGS84 projection reprojected.
Aniruddha
Benjamin Galois wrote:
> Thank you, Aniruddha.
> And thanks to all the contributors who came to my aid.
> The http://www.diva-gis.org/Data.htm provides exactly the shapefile I need.
> Do you know where to find GeoTiff or JPG / JGW files ?
> Benjamin
> The information contained in this document is attorney privileged and
> confidential.The information is intented only for the use of the individual
> or entity named above. Should you receive this message in error, please
> delete
> it immediately from your system and notify the sender of the wrong delivery
> and the mail deletion. If the reader of this message is not the intended
> recipient,
> you are hereby notified that any use, disclosure, dissemination copying
> (either whole or partial) of this document, or any information it contains,
> is strictly prohibited.
> E. mail transmission cannot be guarantee to be secure or error free as
> information could be intercepted, corrupted, lost, destroyed, arrive late
> or incomplete, or contain viruses. The sender Company shall not be liable
> for the contents said document.
> If verification is required please request a hard copy version.
> This email is virus free by TrendMicro Inter Scan Security Suite.
