Passing Variable to a Map File
Damon Broglie
brog at MAIL.UTEXAS.EDU
Tue Dec 6 16:36:47 EST 2005
Thanks for the info Ken, but the gMap Factory applications run MapScript,
and I like the look and feel of the applications.
To simplify things and try to hunt down the problem, I have tried creating
a new point layer which should take a shapefile as its DATA attribute.
In my map file, I created a layer called "shpvar" with class and style
attributes. The only thing missing from the layer is the DATA parameter
(which is set to nothing, i.e. the text box in MapLab is blank).
I added the following line to my <project>.php file in
"maplab/projects/gmf_apps/<project>/" just after the "Process map size" header:
//ADDED
$shpvarLayer = $oMapSession->oMap->getLayerByName("shpvar");
$shpvarLayer->set("status",MS_ON);
$shpvarLayer->set("data", "./us-counties-centroids");
When I run the application to view the map, the layer gets turned on in the
table of contents, but none of the points show up on the map.
Any suggestions?
