[Fwd: Re: [UMN_MAPSERVER-USERS] WFS Server output in udig]
Jody Garnett
jgarnett at REFRACTIONS.NET
Wed Dec 7 15:35:49 EST 2005
Yewondwossen Assefa wrote:
>> As I recall 4.8 had some issue with Intersects being declared
>> incorrectly in its capability
>> file are you using 4.8?
> Do you have more information at what level things are broken ? The
> intersect thing was corrected before the 4.6 release
> (http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1163)
We only found it with testing - let me find the jira bug:
-<http://jira.codehaus.org/browse/GEOT-575>
And you are correct - fixed in 4.6.
I am not aware of any test cases produced for anything greater then 4.7,
normally someone has to stand up a server for the geotools
community to write tests against. Paul Ramsey did 4.4, 4.5, 4.6 just
before the OSG'05. Having a server up for test cases is the only
way to ensure continual compatibility.
Cheers,
Jody
