Compiling with ming-0.3cvs - breaks mapscript?
Mike Leahy
mgleahy at GOLDEN.NET
Thu Dec 8 06:30:55 EST 2005
Hello list,
I'm currently trying to get Mapserver 4.8.0-beta2 running with flash
support. I can get ming-0.3cvs complied and installed - the php_ming.so
will load fine in a test php script I have. However, if I compile
MapServer with ming-0.3, I get a long list of warnings much like the
following:
mapswf.c:3012: warning: passing argument 2 of ‘SWFMovie_add’ from
incompatible pointer type
With ming-0.3beta1, this would then crash, but the cvs continues and
compiles fine (I also added MING_ENABLED="-DUSE_MING_FLASH
-DMING_VERSION_03" in configure.in - I'm not sure if that had any
impact, as I don't remember exactly when I did it).
Finally, when I put the new php_mapscript.so in my php/modules folder, I
find that I am unable to load the module in php.
If I repeat the whole process, and remove '--with-ming' from the
mapserver ./configure command, the whole thing compiles fine, and
php_mapscript.so loads fine. What is it about ming/swf support that
could break mapscript? Am I okay to compile the CGI executables with
SWF support, then recompile everything without swf and just use the php
module with the swf-enabled executables?
Thanks in advance for any help,
Mike
