MapServer, PostGIS, and WFS
Christopher Condit condit at SDSC.EDU
Thu Dec 8 17:58:31 EST 2005
Hi All-
I've got a curious problem with MapServer 4.6 that I'm trying to use for
WMS and WFS.  If I query a shape file layer, everything runs fine.
However, when I attempt the same with a PostGIS layer, things don't go
so smoothly.  The WMS from PostGIS works fine - but the WFS yields
strange results.
When I query the server with:
http://localhost/mapserver/mapserv.exe?MAP=maps/tutorial/example1-5.map&
SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&typename=simpletest&BBOX=-9
0,0,-90,0
I get the following error:
XML Parsing Error: junk after document element
SERVICE=WFS&VERSION=1.0.0&REQUEST=getfeature&typename=simpletestBBOX=-90
,0,-90,0
Line Number 79, Column 1:msPOSTGISLayerRetrievePK: field length =
$imsPOSTGISLayerRetrievePK: field length = $imsPOSTGISLayerRetrievePK:
field length = $i
The data in PostGIS is loaded from the shapefile that _is_ working for
both WMS and WFS.  Is there another step I need to make WFS work with
PostGIS?
Thanks in advance...
Chris
Here's the LAYER definition from my Map file
LAYER
  NAME simpletest
  METADATA
    "wfs_title"    "SimpleWFSTest"
    "wfs_geometry_element_name" "the_geom"
  END
  TYPE POLYGON
  STATUS OFF
  EXTENT        -180 -90 180 90
  CONNECTIONTYPE POSTGIS
  CONNECTION "user=user dbname=shapecache password=blah"
  DATA "the_geom from test"
  CLASS
      COLOR        232 0 0
      OUTLINECOLOR 32 32 32
  END
  DUMP TRUE
  TRANSPARENCY 50
  PROJECTION
    "init=epsg:4326"
  END
END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051208/c378e31a/attachment.html
