Using the 4.x Tutorial
Brian Peschel
brianp at OCCINC.COM
Fri Dec 9 12:37:46 EST 2005
Ok, argueably, the tutorial doesn't help much without the data. When
something doesn't work is that because (for example) the scale of my
data is drastically different than the tutorial data. <shrug>
- B
Sears, Jeremy wrote:
>Quoting From http://hypnos.cbs.umn.edu/tutorial/ ...
>" The dataset used in this tutorial was taken from the U.S. Department of
>the Interior's National Atlas of the United States. You can visit their web
>site at http://www.nationalatlas.gov."
>and continues to say ..
>" When using this tutorial, you are encouraged to use your own dataset."
>Best Regards
>Jeremy
>-----Original Message-----
>From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
>Behalf Of Brian Peschel
>Sent: December 9, 2005 12:09 PM
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: [UMN_MAPSERVER-USERS] Using the 4.x Tutorial
>Being the newbie I am (and from advice from the DEV list), I went to go run
>through the tutorials. So, I started with the first one:
>and I am missing something obvious. Where do I get the data to use for this
>tutorial? I can't seem to find any refernece to it. Under the 'Tutorial
>Data' section, I see that the author got it from nationalatlas.gov, but no
>link to the data I need to run through the tutorials. Any idea where I can
>get the data? I assume it isn't the 'demo' you can download with the source
>for MapServer as the paths are different and I can't seem to find the same
>files.
>Thanks in advance...
