using annotation angles
Don Isgitt
djisgitt at SOUNDENERGY.COM
Fri Dec 9 16:44:55 EST 2005
Fawcett, David wrote:
> Don,
> I believe that you need to use TrueType labels to rotate them.
> David.
Thanks,David.
Following the documentation for that, I added the font
and type keywords under label, created a font.list file containing
the only ttf file (Vera.ttf) I could find on my (linux) computer and
...and ...where does this font.list file belong? I created it in the
same directory as the map file, executed mapserver, no errors, but no
text belonging to that layer/label. I never heard of the Vera font,
perhaps it is a non-printable font!
If you happen to know, perhaps you could respond to the below tacked on
question.
> p.s. What are the units of scale: physical units/pixel? I want to
> dynamically scale the annotation and scale values seem a necessary
> starting point.
Don
