PostGIS error on 4.8b2
Ken Lord
kenlord at GMAIL.COM
Sat Dec 10 22:39:08 EST 2005
Thanks for your fast response Sean.
I'm not setup for mapscript, python, or compiling mapserver. One of
these days I'll have to learn these things.
So I must ask that someone else in the community jumps in and confirms
the patch for bug 1443.
Thanks,
Ken Lord
Vancouver BC
On 12/10/05, Sean Gillies <sgillies at frii.com> wrote:
> Ken,
> Cc yourself to bug 1443. I committed a fix for it and would
> appreciate confirmation.
> Sean
> On Dec 10, 2005, at 8:05 PM, Ken Lord wrote:
> > Here's a temporary fix that may work for certain users for the USING
> > error for PostgreSQL 8.0.3 - PostGIS / mapserver 4.8b2 until the
> > problem is patched.
> > If your dataset is in the same map projection as your output map,
> > simply remove the 'USING srid=3Dxxxxx' from the end of your SQL
> > query in
> > your DATA string.
> > You will again be able to use nested select statements for datasets
> > based on on-the-fly spatial queries etc.
> > As Daryl Herzmann appears to have discovered, the current bug prevents
> > mapserver from dealing with more than one USING tag in your SQL.
> > Paul - Instead of waiting til Monday, I replicated the problem by
> > upgrading my cariboo-gold.no-ip.info website to MS 4.8b2, to try your
> > suggestion of turning on statement logging.
> > - The log shows the same error seen on the webpage '.... syntax error
> > at or near "USING" at character ...' So the database is receiving the
> > request.
> > And without the 'USING srid=3Dxxxxx' in the SQL statement, each map
> > request crams the log with ~30 lines reffering to the 'find_srid'
> > function ... but the map generates properly.
> > Cheers,
> > Ken Lord
> > Vancouver BC
> > On 12/10/05, Ken Lord <kenlord at gmail.com> wrote:
> >> Thanks Daryl,
> >> I saw your patch there, unfortunately I'm one of those hobbled
> >> people
> >> living in the windows world, who hasn't learned how to compile the
> >> software.
> >> So it will be 4.8b3 or beyond for me :)
> >> Cheers,
> >> Ken Lord
> >> Vancouver BC
> >> On 12/10/05, Daryl Herzmann <akrherz at iastate.edu> wrote:
> >>> On Sat, 10 Dec 2005, Ken Lord wrote:
> >>>> Thanks Howard,
> >>>> That bug does seem to cover my problem, I've added a post to the
> >>>> report to confirm that it affects more than just postgresql 8.1 +
> >>>> mapserver 4.8b2.
> >>>> Paul, I'll try your suggestion on Monday. I had simplified my SQL
> >>>> statement when trying to make it work, evidently I could have
> >>>> simplified it more :)
> >>>> On 12/10/05, Howard Butler <hobu at iastate.edu> wrote:
> >>>>> Is <http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=3D1443>
> >>>>> still relevant to this issue (issues with using *both* UNIQUE
> >>>>> and SR=
> > ID)?
> >>> Hi Ken,
> >>> I am nearly positive if you apply my patch included in that bug,
> >>> Postgi=
> > s
> >>> with "USING..." in the data statement will work...
> >>> Hopefully that patch, in some form, is accepted before the next
> >>> release=
> >>> daryl
> >>> * Daryl Herzmann (akrherz at iastate.edu)
> >>> * Program Assistant -- Iowa Environmental Mesonet
> >>> * http://mesonet.agron.iastate.edu
> Sean Gillies
> sgillies at frii dot com
> http://zcologia.com/news
