Flash vs. MapScript support
Mike Leahy
mgleahy at GOLDEN.NET
Sun Dec 11 13:37:03 EST 2005
Hello list,
I'm putting this question forth again to see if it will catch anyone's
eye the second time around. Basically, as described below, if I compile
MapServer on Linux with flash support, something happens to the
php_mapscript.so that prevents it from being loaded by PHP. Would
anyone have any ideas of what I should look for to work around this?
Regards,
Mike
Mike Leahy wrote:
> Hello list,
> I'm currently trying to get Mapserver 4.8.0-beta2 running with flash
> support. I can get ming-0.3cvs complied and installed - the php_ming.so
> will load fine in a test php script I have. However, if I compile
> MapServer with ming-0.3, I get a long list of warnings much like the
> following:
> mapswf.c:3012: warning: passing argument 2 of ‘SWFMovie_add’ from
> incompatible pointer type
> With ming-0.3beta1, this would then crash, but the cvs continues and
> compiles fine (I also added MING_ENABLED="-DUSE_MING_FLASH
> -DMING_VERSION_03" in configure.in - I'm not sure if that had any
> impact, as I don't remember exactly when I did it).
> Finally, when I put the new php_mapscript.so in my php/modules folder, I
> find that I am unable to load the module in php.
> If I repeat the whole process, and remove '--with-ming' from the
> mapserver ./configure command, the whole thing compiles fine, and
> php_mapscript.so loads fine. What is it about ming/swf support that
> could break mapscript? Am I okay to compile the CGI executables with
> SWF support, then recompile everything without swf and just use the php
> module with the swf-enabled executables?
> Thanks in advance for any help,
> Mike
