Flash vs. MapScript support
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Sun Dec 11 16:11:58 EST 2005
Hi There,
You should use the 0.2a version. That is the version that is known to work.
later,
Mike Leahy wrote:
>Hello list,
>I'm putting this question forth again to see if it will catch anyone's
>eye the second time around. Basically, as described below, if I compile
>MapServer on Linux with flash support, something happens to the
>php_mapscript.so that prevents it from being loaded by PHP. Would
>anyone have any ideas of what I should look for to work around this?
>Regards,
>Mike
>Mike Leahy wrote:
>>Hello list,
>>I'm currently trying to get Mapserver 4.8.0-beta2 running with flash
>>support. I can get ming-0.3cvs complied and installed - the php_ming.so
>>will load fine in a test php script I have. However, if I compile
>>MapServer with ming-0.3, I get a long list of warnings much like the
>>following:
>>mapswf.c:3012: warning: passing argument 2 of ‘SWFMovie_add’ from
>>incompatible pointer type
>>With ming-0.3beta1, this would then crash, but the cvs continues and
>>compiles fine (I also added MING_ENABLED="-DUSE_MING_FLASH
>>-DMING_VERSION_03" in configure.in - I'm not sure if that had any
>>impact, as I don't remember exactly when I did it).
>>Finally, when I put the new php_mapscript.so in my php/modules folder, I
>>find that I am unable to load the module in php.
>>If I repeat the whole process, and remove '--with-ming' from the
>>mapserver ./configure command, the whole thing compiles fine, and
>>php_mapscript.so loads fine. What is it about ming/swf support that
>>could break mapscript? Am I okay to compile the CGI executables with
>>SWF support, then recompile everything without swf and just use the php
>>module with the swf-enabled executables?
>>Thanks in advance for any help,
>>Mike
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
