Querying and labeling a WFS layer in Ma pserver WFS client
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Mon Dec 12 05:44:35 EST 2005
Do you have DUMP TRUE set as well as a TEMPLATE defined on your LAYER?
How are you querying your layer? Through Mapserver CGI interface or through
WMS GetFeatureInfo? Can you give us an example request and response?
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens
frequens
Verzonden: maandag 12 december 2005 11:44
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: Re: [UMN_MAPSERVER-USERS] Querying and labeling a WFS layer in
Mapserver WFS client
On 12/8/05, Bart van den Eijnden < BEN at syncera-itsolutions.nl
<mailto:BEN at syncera-itsolutions.nl> > wrote:
For ogrinfo you have to do something like:
ogrinfo thefile.gml myns:xxxlayer -summary
It seems to me the property names include the namespace, so you should use
the full names in LABELITEM etc. Did you try that?
Bart, thanks, "myns:XXX_ID" works in LABELITEM.
I am able to label the WFS provided points.
I am still unable to query the same layer.
BR
frequens
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051212/1167631b/attachment.html
