Having trouble displaying GeoTIFF raster data
Chieko Maene
cmaene at UIC.EDU
Mon Dec 12 15:13:08 EST 2005
Thank you for your kind reply, Mr. Alpert & Mr. McNierney, but I am
still not be able to figure out what is wrong.. sorry.
Mr. Alpert, I am quite sure that I passed the layer="DOP04" just like
any other layers (shapefiles, POSTGIS data).. The one thing that I am
not sure is that I used "init=epsg:26971" projection but in fact all my
data are in feet, not meter. It didn't affect my other shapefiles &
POSTGIS data, but will it affect raster data..?
Mr. McNierney, my "DOP04.tif" file is huge, actually.. 357MB, dimensions
w=25000 x h=15000 in pixel. Could it be a problem..?
NAME campusmap.map
SIZE 600 600
EXTENT 1159128.60 1888822.10 1174680.45 1904373.95
UNITS feet
IMAGETYPE PNG
SHAPEPATH "/test_mapdata/"
# IL STATE PLANE NAD83 UNIT=FEET is my data's projection
# EPSG:26971 is IL STATE PLANE NAD83 UNIT=METER
PROJECTION
"init=epsg:26971"
END
Thank you so much. Chieko
Ethan Alpert wrote:
> Post your EXTENT and PROJECTION information for you map file. Most of
> the time when something just doesn't show up it's and EXTENT/PROJECTION
> problem or you didn't pass layers=DOP04 in the URL
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Chieko Maene
> Sent: Monday, December 12, 2005 10:18 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Having trouble displaying GeoTIFF raster
> data
> I have an 8-bit greyscale aerial photo GeoTiff image (with coordinates
> information in the header) that I want to add to my map, but I cannot
> seem to get it to work. The strange thing is, I don't get any error
> message when rendering the output PNG image - and still there is no
> aerial photo. My map and the GeoTiff are in the same coordinate system
> (init=epsg:26971) so I thought simply adding a layer to the .map file
> would work, but it didn't. I think I am missing something very simple
> but don't know what. Will anybody please advise me? Any input would be
> appreciated.
> My test site is: http://cmaene.lib.uic.edu/apress/campusmap11.php
> I am using PHP/mapscript 4.6 (MapServer for Windows, MS4W, pre-compiled
> .exe version) on Microsoft-IIS/5.1, and here is the version string from
> MapServer & MapScript:
> MapServer version 4.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=JPEG INPUT=POSTGIS
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG PHP MapScript Version
> ($Revision: 1.235 $ $Date: 2005/06/14 16:03:35 $)
> The layer info:
> # the output IMAGETYPE is PNG
> # the input GeoTIFF is in the same SHAPEPATH
> LAYER
> NAME "DOP04"
> TYPE RASTER
> STATUS on
> DATA "DOP4.tif"
> PROJECTION
> "init=epsg:26971"
> END
> END
> I tried:
> - switchig layer status to "on" or "default"
> - adding a world file (.tfw) to the GeoTiff
> 0.550000000000000040
> 0.0
> 0.0
> -0.550000000000000040
> 1159375.2749999999
> 1900374.7250000003
> - adding "PROCESSING" and/or "PROJECTION" classes to the layer in the
> map file to make sure that the GeoTIFF file is read via GDAL.
> - converting the GeoTiff to JPEG using Photoshop and then add a world
> file (.jgw) - again, the airphoto didn't show-up, but no error message.
> - converting the GeoTiff to PNG using tiff2png and PNG2, but the
> conversion attempts failed (lack of memory?? original GeoTIFF is 350 MB,
> or the header information wasn't read properly?)
> I read (among other documents & threads):
> MapServer how-to, Raster Data in MapServer 4.4
> http://ms.gis.umn.edu/docs/howto/raster_data/
> - [Mapserver-users] How to force GDAL to read tiffs?
> http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0405/msg00025.h
> tml
> http://lists.dmsolutions.ca/pipermail/mapserver-users/2004-May/018352.ht
> ml
> - [ms4w-users] When will the next MS4W build be available
> http://lists.maptools.org/pipermail/ms4w-users/2005-October/000310.html
> - [Mapserver-users] Trans.: Gdal, geo tiff raster and mapserver
> http://lists.gis.umn.edu/pipermail/mapserver-users/2004-May/013080.html
Chieko Maene
Map Librarian
Government Documents, Maps and Microforms Department
Richard J. Daley Library
University of Illinois at Chicago
801 S. Morgan, M/C 234
Chicago, Illinois 60607 USA
(312) 996-2738
*new* http://www.uic.edu/~cmaene/maps
