Mapscript getExtent() for postGIS Layer returns strange result
Michael Schulz mschulz at WEBGIS.DE
Tue Dec 13 08:33:30 EST 2005
i have a similar problem here (not mapscript, but mapserver as wms
server), on different servers, running mapserver 4.6.1, PG 8.0.3 /
Postgis: the getCapabilities xml shows strange extents of postgres
layers (in latlon and other srs), far beyond the correct extent. Same
behaviour: examining the extent on the db gives corrects results.
For now i used the extents from the db in the wms_extent parameter.
Cheers, Michael
Christian wolf schrieb:
> Hi again.
> Searching the list/web I couldn't find anything related, so here it goes:
> Using MapServer/Script 46 and PostgreSQL 8.0 and current PostGIS version, I
> get as a result from getExtent()
> -25000000,-25000000 25000000,25000000
> wich is kinda not the extent of my layer. Neither in the data nor in the
> EXTENT definition of the Mapfile. shooting an 'exetent(wkb_geometry)'
> directly returns the correct data.
> Can anyone confirm this? Or did I mess something up?
Michael Schulz                            mschulz at webgis.de
in medias res  Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66              Tel +49 (0)761 556959-5
79108 Freiburg                      Fax +49 (0)761 556959-6
                www.webgis.de / www.zopecms.de
NEU ++ UMN MapServer Hosting ++ http://www.webgis.de ++ NEU
