Legend Labels offset down.
Ken Lord
kenlord at GMAIL.COM
Tue Dec 13 23:50:11 EST 2005
Thanks Steve, The offset parameter did the trick.
I see what you mean by consistancy, the same font behaves fine on my
home system.
Ken
On 12/13/05, Steve Lime <steve.lime at dnr.state.mn.us> wrote:
> You see that offset with some fonts. I'm not sure why and it is not consistent. It could be problems in the way GD is interpreting font metrics or problems with the font file itself (they are not all created equal). Could even be a MapServer bug but if so I would expect a more consistent problem. Anywho there is an easy workaround. Use the LABEL OFFSET parameter to nudge them up a bit (e.g. OFFSET 0 -2).
> Steve
> >>> Ken Lord <kenlord at GMAIL.COM> 12/13/05 8:15 PM >>>
> Hi List,
> In my legend image (not an html legend), with mapserver 4.8b2 CGI,
> the labels for the features in the legend are being placed to the
> lower right of the legend icon, instead of directly to the right.
> This position has the appearance of the default lower right labelling
> position for features on the map, but of course makes the legend
> impossible to read, with all the text offset down, next to the wrong
> legend icon.
> I've confirmed this by setting the Y spacing in the legend to a large
> value to space it all apart.
> I've tried using POSITION cr within the label object of my legend in
> my mapfile, but it does not help (and was not needed in the past
> versions).
> Am I missing something in my settings, or is this possibly a new bug?
> Thanks,
> Ken Lord
> Vancouver BC
