Help! html legend problems
J. Parapar listario at GMAIL.COM
Wed Dec 14 08:03:10 EST 2005
Hi Joanne
I am not sure if this is the case but if you have all your layers as
hidden form parameters, all with the name set to "layer" then you are
including them in every request you make, regardless the legend check
boxes are on or off. Try removing those hidden parameters.
Best regards,
Jorge
2005/12/14, joanne cook <j.cook at oxfordarch.co.uk>:
> Hi Steven,
> Thanks for the response. I have removed the html head and foot tabs- they were important at one point but not anymore. I also changed the name of the checkbox to layer, as you suggested. The layers are all on in the map file, and defined as hidden cgi variables in my web page. Now, when I zoom into scale, the new layers appear switched on, which is good, but if I uncheck the check boxes and click the submit button they stay switched on, whereas I want them to turn off...
> All the best
> Jo
> Joanne Cook BSc MLitt AIFA
> Information Systems Coordinator
> Oxford Archaeology North
> ________________________________
> From: Steven Monai [mailto:stevem at SPATIALMAPPING.COM]
> Sent: Tue 13/12/2005 16:43
> To: MAPSERVER-USERS at LISTS.UMN.EDU; joanne cook
> Subject: Re: Help! html legend problems
> Joanne:
> Change the name of your checkbox from "layer_status" to simply "layer".
> That should allow the MapServer CGI recognize it. Also, if it is your
> intention to embed the legend within a map tempate (via: <table>[legend]
> </table>, for example), then you ought to remove the <html><head>... tags,
> as they will only serve to confuse the browser.
> Did you resolve your layer on/off problem by changing your layers' status
> from ON to DEFAULT? If so, change them back to ON (or OFF), otherwise the
> checkboxes in your legend will be ignored.
> HTH,
> -SM
> On Mon, 12 Dec 2005 09:37:39 -0000, joanne cook <j.cook at OXFORDARCH.CO.UK>
> wrote:
> >Hi Everyone,
> >I have got myself into a terrible mess with html legends and would
> appreciate some assistance, as nothing I do seems to work. I am trying to
> implement a legend with check boxes for layer control, that only displays
> layers that are in scale on the map. So far so good. My legend template is
> shown below:
> >[leg_layer_html Opt_Flag=14]
> ><html>
> ><head>
> ><title></title>
> ></head>
> ><body>
> ><tr bgcolor="#FFFFFF">
> >  <td align="center">
> >    <input type="checkbox" name="layer_status" value="[leg_layer_name]"
> [if name=layer_status oper=neq value=0]CHECKED[/if]>
> >  </td>
> >  <td><img src="[leg_icon height=15 width=15]" height=15 width=15></td>
> >  <td><font face="Arial, Helvetica, sans-serif" size="2">[if
> name=layer_name oper=neq value=][leg_layer_name][/if][if name=layer_name
> value=]* Name Not Set*[/if]</font></td>
> ></tr>
> ></body>
> ></html>
> >[/leg_layer_html]
> >My first problem was that when I zoomed in on the map to a scale at which
> new layers became visible, they appeared switched off in the legend. All
> the layers in my map file have status ON. I resolved that, or so I thought,
> but now when I try and switch layers off in the legend, and refresh my map
> (with a form submit button) they just stay switched on. Also, I don't
> really understand the relationship between having layers declared as cgi
> variables in my web page and the behaviour of the legend.
> >I have searched the documentation on this, and I'm sure it must be
> something very simple that I am missing, so I would really appreciate it if
> someone could help me out.
> >Many thanks
> >Jo
> >This message has been scanned for viruses by BlackSpider MailControl -
> www.blackspider.com
