multiple join {Scanned}
Steve Lime
steve.lime at DNR.STATE.MN.US
Wed Dec 14 10:28:33 EST 2005
I believe there have been some bug fixes along this line applied to both the pending 4.8 release and the 4.6.2 release. If you can get a win32 version of either of those I think you should be fine.
Steve
>>> Siki Zoltan <siki at AGT.BME.HU> 12/14/05 4:38 AM >>>
I get in trouble with multiple join.
It works on linux but fails several times on win32, but not always.
I get unhandled exception 0x7c911e58 in mapserv.exe 0xc0000005
Access violation reading location 0x2f3c3534 using ms4w.
On linux I use
MapServer version 4.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WFS_SERVER INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
On win32 I use (ms4w)
OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=JPEG INPUT=POSTGIS
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
-- my layer definition in map file ---
LAYER
NAME "kafold"
DATA "alapterkep/kafold"
STATUS ON
GROUP "telkek"
TYPE POLYGON
MAXSCALE 15000
CLASS
COLOR -1 -1 -1
OUTLINECOLOR 0 0 0
END
TOLERANCE 0
# template is set though URL
# TEMPLATE "telek_cim.html"
# HEADER "telek_cim_header.html"
# FOOTER "telek_cim_footer.html"
JOIN
NAME cim
TABLE "cimek/ujcimek1.dbf"
FROM HRSZ
TO HRSZ
TYPE multiple
TEMPLATE "cim_template.html"
END
END
-- telek_cim.html ---
[join_cim]
-- cim_template.html --
<tr>
<td valign="top">[HRSZ]</td>
<td valign="top" align="right">[JOGTER]</td>
<td valign="top">[F_TIP]</td>
<td valign="top">[VALTSZ]</td>
<td valign="top">[cim_IRSZAM]</td>
<td valign="top">[cim_CIM]</td>
<td valign="top">[cim_HATSZAM]</td>
</tr>
Any idea?
Thanks
Zoltan
