Help! html legend problems
joanne cook j.cook at OXFORDARCH.CO.UK
Wed Dec 14 11:00:23 EST 2005
Hi Steven,
When the layers are not set as hidden cgi variables and I zoom into scale, the new legend items first appear off rather than on, and don't display on the map. However, when switched on they do maintain their status when the submit button is clicked. The legend is definitely inside the form as well.
Thanks for your perserverance!
Jo
Joanne Cook BSc MLitt AIFA
Information Systems Coordinator
Oxford Archaeology North
From: Steven Monai [mailto:stevem at spatialmapping.com]
Sent: Wed 14/12/2005 15:56
To: joanne cook
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: RE: Help! html legend problems
Joanne:
Try removing the layers from your hidden cgi variables. There should be no
need for them anyway, since you're using the HTML legend to control the
layers' on/off status. Also, be certain that the legend is rendered inside
your <form>, so that the checkboxes contribute their values to the web-page
submission.
-SM
-----Original Message-----
From: joanne cook [mailto:j.cook at oxfordarch.co.uk]
Sent: Wednesday, December 14, 2005 3:47 AM
To: Steven Monai
Hi Steven,
Thanks for the response. I have removed the html head and foot tabs- they
were important at one point but not anymore. I also changed the name of the
checkbox to layer, as you suggested. The layers are all on in the map file,
and defined as hidden cgi variables in my web page. Now, when I zoom into
scale, the new layers appear switched on, which is good, but if I uncheck
the check boxes and click the submit button they stay switched on, whereas I
want them to turn off...
All the best
Jo
From: Steven Monai [mailto:stevem at SPATIALMAPPING.COM]
Sent: Tue 13/12/2005 16:43
To: MAPSERVER-USERS at LISTS.UMN.EDU; joanne cook
Subject: Re: Help! html legend problems
Joanne:
Change the name of your checkbox from "layer_status" to simply "layer".
That should allow the MapServer CGI recognize it. Also, if it is your
intention to embed the legend within a map tempate (via: <table>[legend]
</table>, for example), then you ought to remove the <html><head>... tags,
as they will only serve to confuse the browser.
Did you resolve your layer on/off problem by changing your layers' status
from ON to DEFAULT? If so, change them back to ON (or OFF), otherwise the
checkboxes in your legend will be ignored.
HTH,
-SM
On Mon, 12 Dec 2005 09:37:39 -0000, joanne cook <j.cook at OXFORDARCH.CO.UK>
wrote:
>Hi Everyone,
>I have got myself into a terrible mess with html legends and would
appreciate some assistance, as nothing I do seems to work. I am trying to
implement a legend with check boxes for layer control, that only displays
layers that are in scale on the map. So far so good. My legend template is
shown below:
>[leg_layer_html Opt_Flag=14]
><html>
><head>
><title></title>
></head>
><body>
><tr bgcolor="#FFFFFF">
>  <td align="center">
>    <input type="checkbox" name="layer_status" value="[leg_layer_name]"
[if name=layer_status oper=neq value=0]CHECKED[/if]>
>  </td>
>  <td><img src="[leg_icon height=15 width=15]" height=15 width=15></td>
> <td><font face="Arial, Helvetica, sans-serif" size="2">[if
name=layer_name oper=neq value=][leg_layer_name][/if][if name=layer_name
value=]* Name Not Set*[/if]</font></td>
></tr>
></body>
></html>
>[/leg_layer_html]
>My first problem was that when I zoomed in on the map to a scale at
>which
new layers became visible, they appeared switched off in the legend. All the
layers in my map file have status ON. I resolved that, or so I thought, but
now when I try and switch layers off in the legend, and refresh my map (with
a form submit button) they just stay switched on. Also, I don't really
understand the relationship between having layers declared as cgi variables
in my web page and the behaviour of the legend.
>I have searched the documentation on this, and I'm sure it must be
something very simple that I am missing, so I would really appreciate it if
someone could help me out.
>Many thanks
>Jo
>This message has been scanned for viruses by BlackSpider MailControl -
www.blackspider.com
