multiple join {Scanned}
Siki Zoltan siki at AGT.BME.HU
Wed Dec 14 19:30:42 EST 2005
Hi Steve,
Thank for your answer.
I've tried 4.8.0beta but it also cause illegal operation on win xp prof.
I would like to debug mapserv with Visual Studio but I failed to compile
it with source info. Is there any howto about it?
Thanks
Zoltan
On Wed, 14 Dec 2005, Steve Lime wrote:
> I believe there have been some bug fixes along this line applied to both the pending 4.8 release and the 4.6.2 release. If you can get a win32 version of either of those I think you should be fine.
> Steve
> >>> Siki Zoltan <siki at AGT.BME.HU> 12/14/05 4:38 AM >>>
> Hi,
> I get in trouble with multiple join.
> It works on linux but fails several times on win32, but not always.
> I get unhandled exception 0x7c911e58 in mapserv.exe 0xc0000005
> Access violation reading location 0x2f3c3534 using ms4w.
> On linux I use
> MapServer version 4.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>  OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
>  SUPPORTS=WFS_SERVER INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
>  INPUT=SHAPEFILE
> On win32 I use (ms4w)
>  OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
>  SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
>  SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=JPEG INPUT=POSTGIS
>  INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
> -- my layer definition in map file ---
> LAYER
> 	NAME "kafold"
> 	DATA "alapterkep/kafold"
> 	STATUS ON
> 	GROUP "telkek"
> 	TYPE POLYGON
> 	MAXSCALE 15000
> 	CLASS
> 		COLOR -1 -1 -1
> 		OUTLINECOLOR 0 0 0
> 	END
> 	TOLERANCE 0
> # template is set though URL
> #	TEMPLATE "telek_cim.html"
> #	HEADER "telek_cim_header.html"
> #	FOOTER "telek_cim_footer.html"
> 	JOIN
> 		NAME cim
> 		TABLE "cimek/ujcimek1.dbf"
> 		FROM HRSZ
> 		TO HRSZ
> 		TYPE multiple
> 		TEMPLATE "cim_template.html"
> 	END
> END
> -- telek_cim.html ---
> [join_cim]
> -- cim_template.html --
> <tr>
> 	<td valign="top">[HRSZ]</td>
> 	<td valign="top" align="right">[JOGTER]</td>
> 	<td valign="top">[F_TIP]</td>
> 	<td valign="top">[VALTSZ]</td>
> 	<td valign="top">[cim_IRSZAM]</td>
> 	<td valign="top">[cim_CIM]</td>
> 	<td valign="top">[cim_HATSZAM]</td>
> </tr>
> Any idea?
> Thanks
> Zoltan
